Vinyl Top Replacement Advice
#676540
04/21/10 02:10 PM
04/21/10 02:10 PM
Posts: 88 Lawrence, KS
coledavis01
Lawrence, KS
I'm planning on doing a vinyl top install this weekend on my 69 Bee. Have the top and a local source for the DAP adhesive. I do have a couple of questions though, how much adhesive should be needed for this? The shop will sell it in any qty. needed. Would a sprayer or brush be a better way to apply the adhesive? I have a small 2 oz detail gun but never sprayed an adhesive through it, is some sort of thinning necessary for this? I'm using a Mopar Muscle article from a couple years back for reference but any pointers are appreciated! Thanks, Cole
Re: Vinyl Top Replacement Advice
[Re: Snoopy]
#676554
04/22/10 05:19 PM
04/22/10 05:19 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I saw a tip somewhere to buy 4 cans. You will only use 2 but if you have one clog, you will be watching the swamp rise and aligators nip while you futz with the failed can. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
