73 Duster brakes on a 64 Barracuda #676508
04/21/10 12:17 PM
04/21/10 12:17 PM
Minnesota
snojet Offline OP
snojet  Offline OP
Minnesota
I am using a 73 Duster front disc brake set-up on my 64 Barracuda. I would also like to run the stock sway bar. The problem is that the sway bar links hit the brake caliper. I was told that the calipers should go toward the front. Is that correct? I am also using the 73 Duster brake lines and they will not work if I have the calipers to the back. Please fill me in on this set-up. Thanks for all the help
Re: 73 Duster brakes on a 64 Barracuda [Re: snojet] #676509
04/21/10 01:48 PM
04/21/10 01:48 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The methods that I have heard of involve swapping the entire steering knuckle from side to side so the caliper sits toward the rear. This allows sway bar clearance and is actually better for weight distribution. The Aspen/Volare cars were set up this way, as well as all the Diplomat/5th ave cars. You could use a brake line from one of those cars, but they used a different caliper. The connection to the caliper may be different. Oh yeah... how did you mount the front sway bar? The 73-76 cars had the bar passing through the K frame. The 63-72 was a totally different design.
Re: 73 Duster brakes on a 64 Barracuda [Re: snojet] #676510
04/21/10 01:48 PM
04/21/10 01:48 PM
AndyF Offline
AndyF  Offline
You'll have to make a design change somewhere to get the parts to fit together. Either change the anti-sway bar design like the factory did in 1973 or change the caliper mounting location like the factory did on the FMJ cars.
Re: 73 Duster brakes on a 64 Barracuda [Re: snojet] #676511
04/21/10 01:59 PM
04/21/10 01:59 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
63-66 A-bodies are also narrower than their 67+ counterparts. Sway bar would need to be bent. Also, its a completely different method of attaching on the early cars. Be easier to buy a kit. BTDT
1971 Challenger
Re: 73 Duster brakes on a 64 Barracuda [Re: Kern Dog] #676512
04/21/10 02:00 PM
04/21/10 02:00 PM
Minnesota
snojet Offline OP
snojet  Offline OP
Minnesota
The 64 Barracuda sway bar mounts to the front of the K-frame. I am going to take it apart today and see if I can run the calipers on the back.
Re: 73 Duster brakes on a 64 Barracuda [Re: snojet] #676513
04/21/10 02:07 PM
04/21/10 02:07 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I am using a 73 Duster front disc brake set-up on my 64 Barracuda.... I am also using the 73 Duster brake lines and they will not work if I have the calipers to the back.
You can unbolt the lines from the calipers and turn them 180* so they face the rear when the calipers are rear-mounted (side-to-side spindle swap). The lines have a steel tubing section that can be bent as necessary to prevent stress on the flexible portion with suspension travel. The calipers might hit the shocks when mounted this way, check it for clearance. You don't need to change anything but go easy when turned to full lock.
Re: 73 Duster brakes on a 64 Barracuda [Re: snojet] #676514
04/21/10 03:32 PM
04/21/10 03:32 PM
AndyF Offline
AndyF  Offline
You can easily mount the calipers to the back, the issue is the hose routing. You can either use the late FMJ calipers which are designed to be rear hung or you can have the hard line on the frame go to the front of the wheel like the late B body cars.
There are lots of ways to make the stuff work but that doesn't mean that any random combination of parts will work. For some reason people think they can just bolt randomly selected parts onto their cars and it will all magically work. It isn't quite that simple.
Re: 73 Duster brakes on a 64 Barracuda [Re: AndyF] #676515
04/21/10 06:37 PM
04/21/10 06:37 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The easy solution is to shorten the end links..........
But, there is nothing wrong with swapping the spindles and calipers.
Re: 73 Duster brakes on a 64 Barracuda [Re: Jim_Lusk] #676516
04/22/10 05:41 PM
04/22/10 05:41 PM
Minnesota
snojet Offline OP
snojet  Offline OP
Minnesota
I did get the calipers moved to the back. I think it will work fine. I looked at the brake lines and they are going to be tough. I mite have to make something with aeroquip parts. I did look at cutting the links shorter, but I think they would be to short to work correctly. Thanks for all the help.
Re: 73 Duster brakes on a 64 Barracuda [Re: snojet] #676517
04/22/10 05:53 PM
04/22/10 05:53 PM
I have 74 A discs on a 65 dart w volare hoses, the ones w the bracket on the middle of the hose (cut HALF of it off, you'll see what I mean when you see it & leave the part encircling the hose as it is very tough to get off wo damaging the hose and other than visually it does not interfere w anything). I had to bend the hard line part just the right amount so everything would clear lock to lock but they work OK. but next time I'll get some 11.75 rotors/adapters (probably sliders as that's all I've used and they work good)
Re: 73 Duster brakes on a 64 Barracuda [Re: snojet] #676518
04/22/10 05:59 PM
04/22/10 05:59 PM
AndyF Offline
AndyF  Offline
Best approach is to use the late model FMJ calipers which are designed to be rear hung. Then it is easy to buy a hose that works. When you use the wrong calipers the inlet points the wrong direction and the hose has to loop around.
If you want to use the A body calipers then move the hard line connection to the front so the line crosses over the suspension. That is the way the factory did it on the late B body cars.
