4 speed conversion question (update) #67610
06/04/08 06:35 PM
06/04/08 06:35 PM
Anonymous OP
Anonymous OP
What has to be done to a (440 automatic) crank in order to make it 4 speed compatible?
Thanks,
Mike
Re: 4 speed conversion question #67611
06/04/08 06:47 PM
06/04/08 06:47 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
It needs to be drilled out to accept a bushing or bearing like this:
Re: 4 speed conversion question [Re: In_The_Pink] #67612
06/04/08 06:55 PM
06/04/08 06:55 PM
IN
ahy Offline
ahy  Offline
IN
Drilling may can be necessary but many auto cranks were set up for a 4 speed at the factory. Is it a BB or a SB? Can you post a picture of the end of the crank - that would help tell. Another option is to use a bearing that fits into the torque convertor pilot and shorten (if necessary) the transmission input shaft.
Re: 4 speed conversion question [Re: ahy] #67613
06/04/08 07:00 PM
06/04/08 07:00 PM
Anonymous OP
Anonymous OP
Sorry, i forgot to mention that it's a 440 from a 68 imperial.
The motor has already been rebuilt and i wanted to keep my 64 a pushbutton auto, but i started playing with the idea of making it a 4 speed.
I heard that drilling was necessary but was hoping it was not so involved.
Re: 4 speed conversion question #67614
06/04/08 07:04 PM
06/04/08 07:04 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
You can always cut the input shaft.
Re: 4 speed conversion question [Re: moparpollack] #67615
06/04/08 07:08 PM
06/04/08 07:08 PM
IN
ahy Offline
ahy  Offline
IN
There's a good chance it is already set up for 4 speed - may even have the bronze bushing in place dirty but unworn.
Re: 4 speed conversion question [Re: ahy] #67616
06/04/08 07:11 PM
06/04/08 07:11 PM
Anonymous OP
Anonymous OP
I'll have to take a picture next time i'm at the shop. Could you tell from that?
Re: 4 speed conversion question [Re: ahy] #67617
06/04/08 07:15 PM
06/04/08 07:15 PM
Anonymous OP
Anonymous OP
They can be setup for an auto and manual together?
Re: 4 speed conversion question #67618
06/04/08 08:06 PM
06/04/08 08:06 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
The pic I posted is of my '77 360 which came with a factory 727. The crank was already drilled, so all I had to do was add the bearing, as shown. Keep your that your 440 crank is, too.
Re: 4 speed conversion question #67619
06/05/08 01:07 AM
06/05/08 01:07 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
I pulled a 383 from a 68 Newport years ago...original engine. Went to put a bushing into it for my roadrunner and there was already one there...dirty and unused, but there.
Yours stands alot more chance of beeing drilled being a 68 than if it was a later 70's unit, in my experience. If it's drilled to depth and not finish drilled to size (and many were this way) an SKF B287 fits into the torque converter register and takes care of the bushing issue for you.
As previously mentioned, circumcise the input if you have to.
2 Demons...no, not my kids!
Re: 4 speed conversion question [Re: 4speeds4me] #67620
06/05/08 01:56 AM
06/05/08 01:56 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Even if it's not drilled, they make a bearing for use with an undrilled crank, just sits where the torq converter does, like said above. Then you have to trim the input shaft shorter to make up for the crank not being drilled as deep.
Re: 4 speed conversion question [Re: DaytonaTurbo] #67621
07/05/08 07:49 PM
07/05/08 07:49 PM
Anonymous OP
Anonymous OP
I checked my crank and it is drilled almost 2 inches
deep
Re: 4 speed conversion question #67622
07/05/08 09:48 PM
07/05/08 09:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
deep
thats the first step , now the question is it it reamed to size ?
the plus is you shouldn't have to cut the input shaft if its not fully reamed to size , just use the pilot bushing setup that goes in the convertor register
Re: 4 speed conversion question [Re: JohnRR] #67623
07/05/08 10:03 PM
07/05/08 10:03 PM
Anonymous OP
Anonymous OP
NM
i answered my own question.
