Roller rocker arms for 440 - pics added #675872
04/20/10 05:38 PM
04/20/10 05:38 PM
Up in the North and Far Away
AutoEngineer Offline OP
Hey guys,
We're preparing a street/strip 440 for my friend's '69 Charger and I would need your recommendations for roller rocker arms choice
The 440 is currently as follows
Block: .055 overbored
Pistons: forged, measured CR about 9.8
Crank, rods & pistons precision balanced
Hydraulic cam: Comp Cams 21-225-4
Duration int/exh: 284/296, duration @ .050" Lift: 240/286, Valve Lift: 0.507/0.510, Cam Lobe-Center Angle: 110, but it was set at 106
Heads: 440Source, almost stock
Valve springs: Comp Cams 924-16, Seat load 112 @ 1.900, open load 355 @ 1.200
Intake: Eddy RPM
Headers: Hedman 1-3/4" primaries
We already bought a set of Proform rockers, but their quality was poor. Bushing machining was very very rough and the arm was a little bit too short to align perfectly with the valve tip.
What would you recommend to use with this setup 1.5 or 1.6 rockers and what brand???
I was looking for a set from ebag, PRW Rockers, but had never before heard from them. They looked nice in the picture, but I would not like to try them without any recommendations. The Proform set already was a disappointment, but it was rather cheap. Yes, I can ask myself, can you get good stuff with bottom low price
I would also like to have your opinion about the carb. We have a 750 cfm AVS Carter, but should I leave it on the shelf and buy a bigger carb?
All comments are more than wellcome
Here's link to PRW rockers and a picture PRW Rockers link
Re: Roller rocker arms for 440 [Re: AutoEngineer] #675873
04/20/10 06:52 PM
04/20/10 06:52 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
How much do you want to spend? Harland sharp would be a good choice, but not cheep! Crane Golds would be ok, if you can find them. Oh and leave the AVS on the shelf
Yes I live in Michigan, so there is still 1 light on
Re: Roller rocker arms for 440 [Re: AutoEngineer] #675874
04/20/10 08:05 PM
04/20/10 08:05 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I would look for a set of Isky or Crane iron rockers.I'm using the Crane iron rockers on my 440 that is almost the same combo as yours.
750 Holley is what I'd use.
Nautilus Racing-
Re: Roller rocker arms for 440 [Re: AutoEngineer] #675875
04/20/10 08:13 PM
04/20/10 08:13 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Been running Crane gold rollers for 15 years now on my 340 with 1000s of miles so far. Also put them on my 440 in 2005, so far so good. I also used Crane gold roller rockers on 572 chevy with dart 360 heads. They held up great and never broke and I ran that engine close to 8K RPM.
I think they are a good middle of the road rocker priced fairly. I can't believe HS rockers are so high, but I'm sure there's a reason.
383man [Re: Chris2581] #675876
04/21/10 01:29 AM
04/21/10 01:29 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yep thats what I use on my 63's 440. In fact my combo is close to yours but I have iron 906 heads and the MP .557 cam. Same hedman headers and the Holley Street Dominator intake. I use an 850 DP as I had my buddy loan me a brand new one and it works so good I made him a deal and kept it. I drive it alot on the street as thats 90 % of the driving on the car. But it never fouls plugs. In fact I ran my best of 11.49 last Oct with plugs that had been in the car for over a year. So I like the basic 850 DP. I have the Isky 1.5 iron ductile rockers and they work good. I got them used for a real good price and like I said they work real good. You wont really go faster with roller rockers if you go any faster at all. But roller rockers are much easier on the valve train parts and the valve guides. I guess you have to ask yourself if its worth the extra money for the roller rockers. Ron
Re: 383man [Re: 383man] #675877
04/21/10 09:15 AM
04/21/10 09:15 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Roller rockers are one of the worst possible places to try to save money. That deserves repeating, Roller rockers are one of the worst possible places to try to save money.
I would use Isky or Crane Iron rockers instead of cheap roller rockers, every time. If you want/need rollers then you need to spend a lot more to get decent ones. Hughes, Crane Gold, Rockerarm Specialist & Harland Sharp come to mind for a mid range rocker. But honestly I think any roller rocker is unnecessary overkill with your cam. I have seen plenty of MP 509 cams run fine with stock stamped rockers but the rocker ratio is a little low with them and will likely cost a little power. I use Isky iron with a cam that has slightly less duration and slightly more lift than yours. The same set of rockers were used with .590 lift for several years with no problems but at that point one of the rollers mentioned above may be more appropriate.
Re: Roller rocker arms for 440 [Re: AutoEngineer] #675878
04/21/10 11:51 AM
04/21/10 11:51 AM
If you really want a decent set of true aluminumm roller rockers , not a set of extruded roller tip rockers then buy a set of Harland Sharps or T&D. Niether set will be cheap, another option, especially for wht your doing is to buy a used set of ductile iron rockers and send them to R.A.S. (Rocker Arm Specialitys) and have them blueprint, bushed and change the ratio to 1.6
Way better way to go than buy a cheap set of aluminum non rolle rockers
Re: Roller rocker arms for 440 [Re: Cab_Burge] #675879
04/21/10 12:20 PM
04/21/10 12:20 PM
GomangoCuda Offline
GomangoCuda  Offline
I didn't even mention T&D and Jessel rockers for 2 reasons.
1. you seem to be looking for a budget solution and they aren't it
2. Horrendous overkill for your engine.
IMHO even the Sharps are overkill for this engine. I have Sharps on the shelf and Iskys in the motor.
Cab: How much $$ does RAS want to fixup the iron rockers like you described? How does the tip alignment and scrub look after changing the ratio?
Re: Roller rocker arms for 440 [Re: AutoEngineer] #675880
04/21/10 12:27 PM
04/21/10 12:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You could probably get by with the stock rockers for that build. I got a set of Scat rollers at Carlise a few years ago for $150 new.
Coming soon!!!!
Re: Roller rocker arms for 440 [Re: GomangoCuda] #675881
04/21/10 12:33 PM
04/21/10 12:33 PM
I haven't had a set done in over eight years so on the price it's better to call them. They correct the tips , all three sets that I had done came out better on the tip alignment and scrub than any stock set of ductile iron uncorrected ones I've seen or had. I think that RAS is the only company that most NHRA stock class racers use to fix there ductile iron rockers, oops, maybe I shouldn't have let that cat out of the bag
Re: Roller rocker arms for 440 [Re: AutoEngineer] #675882
04/21/10 12:58 PM
04/21/10 12:58 PM
DANBURY CT
fury62 Offline
fury62  Offline
DANBURY CT
check out CV products in NC, got the best price for T&D rockers ask for the online discount that's 5% more savings
Re: Roller rocker arms for 440 [Re: fury62] #675883
04/21/10 01:38 PM
04/21/10 01:38 PM
GomangoCuda Offline
GomangoCuda  Offline
Yea, lets put $900 rocker arms on a .510 lift hydraulic cam.
Re: Roller rocker arms for 440 [Re: GomangoCuda] #675884
04/21/10 01:46 PM
04/21/10 01:46 PM
CHANDLER, AZ
512 VALIANT Offline
512 VALIANT  Offline
CHANDLER, AZ
Hughes makes a good rocker and not as expensive as harland sharp here is the link
http://www.hughesengines.com/Index/produ...mp;partid=22770
I run the 1.6:1 on my 505 13.1 comp 700+hp solid roller car.
Re: Roller rocker arms for 440 [Re: AutoEngineer] #675885
04/21/10 01:50 PM
04/21/10 01:50 PM
AndyF Online content
AndyF  Online Content
Just use stock rocker arms on that cam.
Re: Roller rocker arms for 440 [Re: GomangoCuda] #675886
04/21/10 01:57 PM
04/21/10 01:57 PM
CHANDLER, AZ
512 VALIANT Offline
512 VALIANT  Offline
CHANDLER, AZ
I agree (even after rec hughes brand) this is mild build there is no reason for high $ rockers. Also the 750 cfm should be fine.
Re: Roller rocker arms for 440 [Re: GomangoCuda] #675887
04/21/10 02:00 PM
04/21/10 02:00 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
LOL. Yea $ 900.00 rockers on $ 900.00 heads.
Re: Roller rocker arms for 440 [Re: Harley] #675888
04/21/10 02:19 PM
04/21/10 02:19 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
if you really want adjustable rockers for that setup i'd look around for a clean used set of isky's or cranes as even these are expensive or harder to find new. shame there was a guy had a set of iskys in the moparts parts section for $100 but i'll bet they're gone now
Re: Roller rocker arms for 440 [Re: AutoEngineer] #675889
04/21/10 02:37 PM
04/21/10 02:37 PM
Hi guys, thanx a lot for your answers
I have now much more ideas.
We have had some kind of budget and already have exceeded it , but the target is to make it right at once. Aim is to have such combo that will deliver many many years of care-free miles.
And first of all, BEAT the buddy's neighbour's FORD that is running high 12's. The FORD guy been burning sooo much tire at the front of our MOPAR garage that now it must come to an end.
Don't take this too seriously, but half true
OK, enough for joking, now back to the facts of this topic.
T&D, Jesel and Sharps are out of the budget.
Nobody was suggesting the 440 Source rockers, I guess why
I was looking at them at an other buddy's garage and I didn't like the tiny needle bearings they have. Some other brands seem to have alike too, like Cat. I have earlier heard that the fulcrum needle bearings have caused excessive wear on the rocker shaft?
I was also comparing the prices of ductile iron Isky and Crane, but they seem to more pricey than the Crane Gold set, even at shop list prices without any discounts.
Locally I could have a set of 1.6 Crane Gold rockers at an attactive price.
Most of the BB Mopar roller rocker sets seem to have offset rockers, left and right, but the PRW's look like they all are identical. Has anyone experience from them?
Would you prefer 1.5 or 1.6 ratio?
I forgot from the first mail some important specs of the car:
Converter: 2800 stall
Rear end: 3.73 or 3.91
What do you experts say, could this combo be enough to run high or mid 12's?
I know Charger is heavy, so should we break the piggy bank to increase the budget
Re: Roller rocker arms for 440 [Re: AutoEngineer] #675890
04/21/10 02:46 PM
04/21/10 02:46 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Look in the engines and race parts for sale sections on this site.I'm sure there was a set of iron Crane's or Isky's for sale.
If that Charger doesn't run 12.40's at least,something is dead wrong.I think it will run faster.
Nautilus Racing-
Re: Roller rocker arms for 440 [Re: Chris2581] #675891
04/21/10 03:28 PM
04/21/10 03:28 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We had a similar combo in a 64 Plymouth with steel heads and just ran the HD stamped rockers from Mopar Performance. With 3.91's the car weighed 3350 w/o driver and ran 11.70's in good air through a 3" exhaust. Get an 850 DP if you plan to race it alot. Smoke that Ford!
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
