Roller Cam for small block??
#675359
04/20/10 06:48 AM
04/20/10 06:48 AM
Posts: 96 Australia
gg408
Australia
Hey guys, who would you recommend to grind me a street roller for my 410SB mopar? Is there a nitrous specifc grind needed if only using 175hp shot? Thanks in advance GG408
Re: Roller Cam for small block??
[Re: gg408]
#675360
04/20/10 09:31 AM
04/20/10 09:31 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Hey guys,
No nitrous grind required for a 175 shot. I have a Comp Cam XR286R in my 416. The next size up is the XR292R. These are both considered "street grind rollers" by Comp.
[Re: BobR]
#675361
04/20/10 09:45 AM
04/20/10 09:45 AM
Posts: 84 NC
Badfish67
NC
If you want to take full advantage of the nitrous then you should get a cam made for spray...but you will lose some power when your not running spray. Just call Comp Cams and tell them what your looking to do and they will set you up.
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: emarine01]
#675363
04/20/10 09:57 AM
04/20/10 09:57 AM
BobR
Left Coast
Depends on exhaust flow, even @ 175 shot exhaust duration and lift should be looked at if you want good performance
On our last combo we ran 3 foggers and about 700 HP worth of spray. When we changed over to the Procharger we used the SAME cam. Yes, there may be a small amount of gain by having a special grind but it's not even worth the trouble with a street engine and a 175 shot.
[Re: BobR]
#675364
04/20/10 12:43 PM
04/20/10 12:43 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
as far as grinding, I'm happy with the regrind of a stock hydraulic roller Bullet did for me www.bulletcams.com
[Re: BobR]
#675365
04/20/10 05:32 PM
04/20/10 05:32 PM
Posts: 3,695 nc
emarine01
nc
Cool It sounds like you have a good flowing exhaust port, Unfortunately not all small block exhaust ports are good, The additional 175 could just back up the port more, a cam with some extra exhaust duration for No2 will usually help , it did on our J heads with 150 shot
[Re: emarine01]
#675366
04/20/10 06:40 PM
04/20/10 06:40 PM
Posts: 96 Australia
gg408
Australia
Using W2 econos with port work and 1 7/8" headers so I'm hoping the exaust side shouldn't be to much of a problem.
Cheers GG408
[Re: RobX4406]
#675368
04/20/10 11:31 PM
04/20/10 11:31 PM
BobR
Left Coast
Talk with Brian, member OU812/IMM
He can get you something that will work really well.
Good advice.
[Re: RobX4406]
#675369
04/21/10 06:16 AM
04/21/10 06:16 AM
Posts: 96 Australia
gg408
Australia
Kool thanks for that.
Cheers GG408
