Re: No antifreeze in the car at the dragstrip!
[Re: galen]
#675057
04/20/10 11:39 AM
04/20/10 11:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
How many bottles of water wetter do you guys add with just distilled water?
I use 2 bottles... I have a decent size cooling system (but not big)... I cant see it hurting anything
[Re: dvw]
#675060
04/20/10 08:49 PM
04/20/10 08:49 PM
MR_P_BODY
I've always wondered. Why are we so worried about anti-freeze when the car has oil,trans,axle,and some times power steering fluid. They can all leak. they're all slippery. Just wondering. Doug
Because the oil dry works only on certain things and thats what the tracks use
[Re: MR_P_BODY]
#675061
04/20/10 09:05 PM
04/20/10 09:05 PM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
http://www.youtube.com/user/SCATPACKTOMCar before me blew the bypass hose off- straight antifreeze. Fluid is fluid, wouldn't have been any different if it was any other fluid a race car requires. Just clean up time
[Re: MR_P_BODY]
#675062
04/20/10 09:22 PM
04/20/10 09:22 PM
Posts: 2,177 ill
dennismopar73
ill
water lube is a meaningless term by todays standards water pumps in all cars in say 58 up era isnt required but in the old days when you had to 'pack' your'e pumps it was there is nothing you can use in todays market that will lube a maintance free pump water wetter works as a ph balancer for h2o distilled water is the prefered h2o to be used in cooling systems but not the 'cure all' that is were water wetter comes in and helps the ph balance, there are others out there in the big truck world that works even better you can get ph strips at youre neighborhood drug store or any big truck repair shop
[Re: MR_P_BODY]
#675063
04/20/10 09:25 PM
04/20/10 09:25 PM
Posts: 2,177 ill
dennismopar73
ill
i would only hope they are not using oil dry oil dry is just dirt i would think ,, if they are up on the new ground up corn cobb ' stuff because not even the normal 'oil dry can pick up sythec oils just a thought
[Re: dennismopar73]
#675064
04/20/10 10:35 PM
04/20/10 10:35 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
a flame can pick up ...burn off whatever hydry cant.. but glycol...is nasty..it wont burn off..and still leaves a slick residue. besides.. when water just dries up...why wouldnt you make removing it from the race cars manditory. spill water on track..in mid day. a few minuutes its gone... drip a little it mops up.. one its gone its gone...dried up. all the other stuff ..your talkin down time in the hour range...and that doesnt account for spots you missed... when you can prevent something...with forethought..why wouldnt you...? cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: dennismopar73]
#675065
04/20/10 10:53 PM
04/20/10 10:53 PM
MR_P_BODY
They use oil dry... so does NASCAR... it brooms off or use a blower
[Re: MR_P_BODY]
#675066
04/21/10 05:53 AM
04/21/10 05:53 AM
Quicktree
gainesvilee uses ground peanut hulls not oil dry. I haven't seen anybody use the old oil dry in many years.
[Re: BobR]
#675069
04/21/10 10:18 AM
04/21/10 10:18 AM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
The NHRA used to use rice hull ash.
This is what our track uses
[Re: VernMotor]
#675070
04/21/10 12:22 PM
04/21/10 12:22 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
here's what I use at home...
[Re: Mr.Yuck]
#675071
04/21/10 03:39 PM
04/21/10 03:39 PM
Posts: 2,709 NJ central
Scamp408
NJ central
If you bought the multiple cat formula you could use it on diff oils. LOL
[Re: MR_P_BODY]
#675072
04/21/10 04:40 PM
04/21/10 04:40 PM
Quicktree
Never been down there but all of the places I have been to in the north use oil dry... it always amazes me how many bags they bring.... I worked with a few different groups as a fuel expert for 14 years... was a good time
thats because yoiu guys up north are 20 years behind times
[Re: VernMotor]
#675073
04/21/10 04:41 PM
04/21/10 04:41 PM
Quicktree
yea thats what I was talking about. thats what they use down here. I think they used peanut hulls for a while though.
Post deleted by Defbob
[Re: BobR]
#675074
04/21/10 04:47 PM
04/21/10 04:47 PM
#675075
04/21/10 04:50 PM
04/21/10 04:50 PM
Quicktree
I think I smoked some of that back in the day
yea me too, thats why I can't remember anything
