Page 2 of 3 1 2 3
Re: No antifreeze in the car at the dragstrip! [Re: MR_P_BODY] #675056
04/20/10 11:33 AM
04/20/10 11:33 AM
Missouri
galen Offline
galen  Offline
Missouri
How many bottles of water wetter do you guys add with just distilled water?
Re: No antifreeze in the car at the dragstrip! [Re: galen] #675057
04/20/10 11:39 AM
04/20/10 11:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use 2 bottles... I have a decent size cooling system
(but not big)... I cant see it hurting anything
Re: No antifreeze in the car at the dragstrip! [Re: galen] #675058
04/20/10 08:06 PM
04/20/10 08:06 PM
Lehigh Acres, Florida
rickstershemi Offline
1-bottler here
Rickster
Re: No antifreeze in the car at the dragstrip! [Re: MR_P_BODY] #675059
04/20/10 08:23 PM
04/20/10 08:23 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've always wondered. Why are we so worried about anti-freeze when the car has oil,trans,axle,and some times power steering fluid. They can all leak. they're all slippery. Just wondering.
Doug
Re: No antifreeze in the car at the dragstrip! [Re: dvw] #675060
04/20/10 08:49 PM
04/20/10 08:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
Because the oil dry works only on certain things and
thats what the tracks use
Re: No antifreeze in the car at the dragstrip! [Re: MR_P_BODY] #675061
04/20/10 09:05 PM
04/20/10 09:05 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
http://www.youtube.com/user/SCATPACKTOM
Car before me blew the bypass hose off- straight antifreeze. Fluid is fluid, wouldn't have been any different if it was any other fluid a race car requires. Just clean up time
Re: No antifreeze in the car at the dragstrip! [Re: MR_P_BODY] #675062
04/20/10 09:22 PM
04/20/10 09:22 PM
ill
dennismopar73 Offline
ill
water lube is a meaningless term by todays
standards
water pumps in all cars in say 58 up era isnt required
but in the old days when you had to 'pack' your'e
pumps it was
there is nothing you can use in todays market
that will lube a maintance free pump
water wetter works as a ph balancer for h2o
distilled water is the prefered h2o to be used in
cooling systems but not the 'cure all'
that is were water wetter comes in
and helps the ph balance,
there are others out there in the big truck
world that works even better
you can get ph strips at youre neighborhood drug store
or any big truck repair shop
Re: No antifreeze in the car at the dragstrip! [Re: MR_P_BODY] #675063
04/20/10 09:25 PM
04/20/10 09:25 PM
ill
ill
i would only hope they are not using oil dry
oil dry is just dirt
i would think ,, if they are up on the new
ground up corn cobb ' stuff
because not even the normal 'oil dry can pick up
sythec oils
just a thought
Re: No antifreeze in the car at the dragstrip! [Re: dennismopar73] #675064
04/20/10 10:35 PM
04/20/10 10:35 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
a flame can pick up ...burn off whatever hydry cant..
but glycol...is nasty..it wont burn off..and still leaves a slick residue.
besides..
when water just dries up...why wouldnt you make removing it from the race cars manditory.
spill water on track..in mid day.
a few minuutes its gone...
drip a little it mops up..
one its gone its gone...dried up.
all the other stuff ..your talkin down time in the hour range...and that doesnt account for spots you missed...
when you can prevent something...with forethought..why wouldnt you...?
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: No antifreeze in the car at the dragstrip! [Re: dennismopar73] #675065
04/20/10 10:53 PM
04/20/10 10:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
sythec oils
just a thought
They use oil dry... so does NASCAR... it brooms off or
use a blower
Re: No antifreeze in the car at the dragstrip! [Re: MR_P_BODY] #675066
04/21/10 05:53 AM
04/21/10 05:53 AM
Q
Quicktree Offline
Quicktree  Offline
Q
sythec oils
just a thought
use a blower
gainesvilee uses ground peanut hulls not oil dry. I haven't seen anybody use the old oil dry in many years.
Re: No antifreeze in the car at the dragstrip! [Re: Quicktree] #675067
04/21/10 08:23 AM
04/21/10 08:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
use a blower
Never been down there but all of the places I have
been to in the north use oil dry... it always amazes
me how many bags they bring.... I worked with a few
different groups as a fuel expert for 14 years...
was a good time
Re: No antifreeze in the car at the dragstrip! [Re: MR_P_BODY] #675068
04/21/10 08:59 AM
04/21/10 08:59 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The NHRA used to use rice hull ash.
Re: No antifreeze in the car at the dragstrip! [Re: BobR] #675069
04/21/10 10:18 AM
04/21/10 10:18 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
This is what our track uses
Re: No antifreeze in the car at the dragstrip! [Re: VernMotor] #675070
04/21/10 12:22 PM
04/21/10 12:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
here's what I use at home...
Re: No antifreeze in the car at the dragstrip! [Re: Mr.Yuck] #675071
04/21/10 03:39 PM
04/21/10 03:39 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
If you bought the multiple cat formula you could use it on diff oils. LOL
Re: No antifreeze in the car at the dragstrip! [Re: MR_P_BODY] #675072
04/21/10 04:40 PM
04/21/10 04:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
use a blower
was a good time
thats because yoiu guys up north are 20 years behind times
Re: No antifreeze in the car at the dragstrip! [Re: VernMotor] #675073
04/21/10 04:41 PM
04/21/10 04:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yea thats what I was talking about. thats what they use down here. I think they used peanut hulls for a while though.
Post deleted by Defbob [Re: BobR] #675074
04/21/10 04:47 PM
04/21/10 04:47 PM
Re: No antifreeze in the car at the dragstrip! #675075
04/21/10 04:50 PM
04/21/10 04:50 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I think I smoked some of that back in the day
yea me too, thats why I can't remember anything
Page 2 of 3 1 2 3
