torsion bar removal #674934
04/19/10 05:27 PM
04/19/10 05:27 PM
MA.
P
plymguy Offline OP
plymguy  Offline OP
P
MA.
Where can I get a good torsion bar removal tool? I have seen different ones but I would to get a good one that will do any bar. Thanks for any info here.
John
Re: torsion bar removal [Re: plymguy] #674935
04/19/10 05:29 PM
04/19/10 05:29 PM
NC
Badfish67 Offline
Badfish67  Offline
NC
Are you planning on using them again? If not, just cut them in half and pull both parts out.
1967 Barracuda 360ci/727 9.723ET @139.44mph
Re: torsion bar removal [Re: plymguy] #674936
04/19/10 05:30 PM
04/19/10 05:30 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I made my own out of 1 1/4" square bar. I need to take some pics. Works very well.
Re: torsion bar removal [Re: Todd] #674937
04/19/10 05:46 PM
04/19/10 05:46 PM
Phoenix, Arizona
HerboldRacing Offline
Phoenix, Arizona
This is what I do - remove the nut that secures the lower control arms to the k member. Then use a hammer and hit the side of the control arm so it moves the arm (and torsion bar) an inch or two towards the back of the car. Now get on the other side of the control arm, grab the torsion bar (wear gloves) and whack on the control arm (moving it forwards) while pulling backwards on the torsion bar. Keep hitting the control arm - each hit makes the torsion bar vibrate/bounce out about 1/16 inch. Repeat until the torsion bar is out. Don't ever hit the torsion bar itself.
Edit: And don't forget to remove the torsion bar retaining clip first!!! :-)
Marvin Herbold 1973 Plymouth Duster 340 Drag Car Blog - http://www.HerboldRacing.com Videos - http://www.YouTube.com/mherbold Pictures - http://gallery.herbold-family.com/main.php?g2_itemId=10331
Re: torsion bar removal [Re: HerboldRacing] #674938
04/19/10 06:19 PM
04/19/10 06:19 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Doesn't that booger up your LCA?
Re: torsion bar removal [Re: PAINT IT BLACK] #674939
04/19/10 06:57 PM
04/19/10 06:57 PM
Phoenix, Arizona
Phoenix, Arizona
Booger it up how? I just hit the flat part on the side of the LCA, and not very hard either. I use something like a 12 oz hammer. The LCA is a real stout piece of metal.
Re: torsion bar removal [Re: HerboldRacing] #674940
04/19/10 07:04 PM
04/19/10 07:04 PM
BDW Online content
BDW  Online Content
I've seen people take an old gooseneck from a bike for a cheapie tool. If your only going to use it once, worth a try.
Re: torsion bar removal [Re: BDW] #674941
04/19/10 07:18 PM
04/19/10 07:18 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
what's a gooseneck?
Re: torsion bar removal [Re: DrCharles] #674942
04/19/10 07:26 PM
04/19/10 07:26 PM
Phoenix, Arizona
Phoenix, Arizona
what's a gooseneck?
The part of the goose between the head and the body.
Re: torsion bar removal [Re: HerboldRacing] #674943
04/19/10 07:31 PM
04/19/10 07:31 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I didn't plan on using my torsion bars again so I just put vice grips on them and a hammer. Worked great.
Re: torsion bar removal [Re: plymguy] #674944
04/19/10 07:32 PM
04/19/10 07:32 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Flat rate front-end mechanics don't need no stinkin' specialty tools when there's a BFH and a large pry bar handy (which they always are).
AFTER removing all the twist in the bar, the appropriate fasteners, strut rod stuff, clips, etc:
1. Pry the LCA away from the K member to push the T-bar out of the rear socket.
2. Tap the LCA forward (whilest grasping the T-bar with your other hand) to get the front socket off of the T-bar.
Hurt the poor widdle LCA? Bwahahahahah.
(Okay, if you have a concourse-level restoration on your suspension, maybe you can pad your hammer and pry bar with some rags.)
Down to just a blue car now.
Re: torsion bar removal [Re: 68HemiB] #674945
04/19/10 07:35 PM
04/19/10 07:35 PM
BDW Online content
BDW  Online Content
Ah come on, everyone knows what a gooseneck is.
Re: torsion bar removal [Re: 68HemiB] #674946
04/19/10 07:38 PM
04/19/10 07:38 PM
Phoenix, Arizona
Phoenix, Arizona
This is essentially what I said I do to get the torsion bar off. But you described it better. Thanks. :-)
But to add... for part 2 (the tapping the LCA forward) - even if the LCA is already all the way forward and the torsion bar is still stuck in the socket - just wail away at the LCA... the shock/vibration/bounce will cause the torsion bar to back out of the socket with each hit. For me the torsion bar moved out of the socket about 1/16" of the way with each strike of my hammer on the LCA.
Re: torsion bar removal [Re: BDW] #674947
04/19/10 07:54 PM
04/19/10 07:54 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
thanks... I recognize that part, just never heard it called a gooseneck before. In fact I never heard it called anything before!
How about wrapping a piece of soft aluminum sheet around the bar and clamping a visegrip on it, then just smack with a hammer? The aluminum would have to be thick enough so the visegrip teeth don't hit the bar, of course.
Re: torsion bar removal [Re: DrCharles] #674948
04/19/10 08:15 PM
04/19/10 08:15 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The 90's and earlier style BMX stems work good. They upper half is held in place with 4 allen head bolts. The one pictured above would be harder to get over the t-bar. In fact, they aren't even designed to open up that far and would probably break or become very deformed in the process.
http://www.bikepartsplace.com/images/med/31865557.jpg
Re: torsion bar removal [Re: Neil] #674949
04/19/10 09:47 PM
04/19/10 09:47 PM
IN
ahy Offline
ahy  Offline
IN
The tool Mancini sells is stout and easy to use. Much better than my homemade one.
Re: torsion bar removal [Re: plymguy] #674950
04/20/10 01:42 AM
04/20/10 01:42 AM
maryland
cynic Offline
cynic  Offline
maryland
Just use a brace that is put in concrete to hold wooden posts up and a couple of muffler clamps, 2 1/8 inch, and a 5 lb hammer and they usually come right out.
Re: torsion bar removal [Re: ahy] #674951
04/20/10 01:47 AM
04/20/10 01:47 AM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I made my own from a couple of two-by-fours and some steel plates:
Re: torsion bar removal [Re: HerboldRacing] #674952
04/20/10 11:46 AM
04/20/10 11:46 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That's how I do it also. Never caused any damage...
Re: torsion bar removal [Re: Fab64] #674953
04/20/10 11:49 AM
04/20/10 11:49 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Thats what the one I made looks like but out of steel. I put a cut off piece dog collar and put it around the t-bar and bolted it tight.
