Re: torsion bar removal
[Re: plymguy]
#674935
04/19/10 05:29 PM
04/19/10 05:29 PM
Posts: 84 NC
Badfish67
NC
Are you planning on using them again? If not, just cut them in half and pull both parts out.
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: Todd]
#674937
04/19/10 05:46 PM
04/19/10 05:46 PM
Posts: 127 Phoenix, Arizona
HerboldRacing
Phoenix, Arizona
This is what I do - remove the nut that secures the lower control arms to the k member. Then use a hammer and hit the side of the control arm so it moves the arm (and torsion bar) an inch or two towards the back of the car. Now get on the other side of the control arm, grab the torsion bar (wear gloves) and whack on the control arm (moving it forwards) while pulling backwards on the torsion bar. Keep hitting the control arm - each hit makes the torsion bar vibrate/bounce out about 1/16 inch. Repeat until the torsion bar is out. Don't ever hit the torsion bar itself.
Edit: And don't forget to remove the torsion bar retaining clip first!!! :-)
[Re: HerboldRacing]
#674938
04/19/10 06:19 PM
04/19/10 06:19 PM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
Doesn't that booger up your LCA?
[Re: PAINT IT BLACK]
#674939
04/19/10 06:57 PM
04/19/10 06:57 PM
HerboldRacing
Phoenix, Arizona
Booger it up how? I just hit the flat part on the side of the LCA, and not very hard either. I use something like a 12 oz hammer. The LCA is a real stout piece of metal.
[Re: plymguy]
#674944
04/19/10 07:32 PM
04/19/10 07:32 PM
Posts: 9,312 SoCal
68HemiB
SoCal
Flat rate front-end mechanics don't need no stinkin' specialty tools when there's a BFH and a large pry bar handy (which they always are).
AFTER removing all the twist in the bar, the appropriate fasteners, strut rod stuff, clips, etc:
1. Pry the LCA away from the K member to push the T-bar out of the rear socket.
2. Tap the LCA forward (whilest grasping the T-bar with your other hand) to get the front socket off of the T-bar.
Hurt the poor widdle LCA? Bwahahahahah.
(Okay, if you have a concourse-level restoration on your suspension, maybe you can pad your hammer and pry bar with some rags.)
Down to just a blue car now.
[Re: 68HemiB]
#674946
04/19/10 07:38 PM
04/19/10 07:38 PM
HerboldRacing
Phoenix, Arizona
This is essentially what I said I do to get the torsion bar off. But you described it better. Thanks. :-)
But to add... for part 2 (the tapping the LCA forward) - even if the LCA is already all the way forward and the torsion bar is still stuck in the socket - just wail away at the LCA... the shock/vibration/bounce will cause the torsion bar to back out of the socket with each hit. For me the torsion bar moved out of the socket about 1/16" of the way with each strike of my hammer on the LCA.
[Re: BDW]
#674947
04/19/10 07:54 PM
04/19/10 07:54 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Ah come on, everyone knows what a gooseneck is.
thanks... I recognize that part, just never heard it called a gooseneck before. In fact I never heard it called anything before!
How about wrapping a piece of soft aluminum sheet around the bar and clamping a visegrip on it, then just smack with a hammer? The aluminum would have to be thick enough so the visegrip teeth don't hit the bar, of course.
[Re: DrCharles]
#674948
04/19/10 08:15 PM
04/19/10 08:15 PM
Posts: 20,637 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
The 90's and earlier style BMX stems work good. They upper half is held in place with 4 allen head bolts. The one pictured above would be harder to get over the t-bar. In fact, they aren't even designed to open up that far and would probably break or become very deformed in the process. http://www.bikepartsplace.com/images/med/31865557.jpg
[Re: HerboldRacing]
#674952
04/20/10 11:46 AM
04/20/10 11:46 AM
Posts: 6,516 Santa Cruz, California
Lefty
That's how I do it also. Never caused any damage...
[Re: Fab64]
#674953
04/20/10 11:49 AM
04/20/10 11:49 AM
Posts: 1,377 Ohio
Todd
Ohio
I made my own from a couple of two-by-fours and some steel plates:
Thats what the one I made looks like but out of steel. I put a cut off piece dog collar and put it around the t-bar and bolted it tight.
