A body - Mini tubs/Cal Tracs/stock gas tank ,Tailpipes? #673875
04/18/10 03:18 PM
04/18/10 03:18 PM
The Swamp
Sixpak Offline OP
Sixpak  Offline OP
The Swamp
Rather than hijack someone else's exhaust post, I thought I'd start one here. I see most guys when they mini tub an A body and want to run tail pipes, they usually mount a fuel cell. But I want to keep a stock tank, and run 3" exhaust, including tail pipes. Anyone ever fit up something like this before? I remember seeing a pic of a 70 Dart that had the pipes angled as they crossed the axle - maybe someone remembers it....might have been a Canadian car...
Re: A body - Mini tubs/Cal Tracs/stock gas tank ,Tailpipes? [Re: Sixpak] #673876
04/18/10 08:37 PM
04/18/10 08:37 PM
parma,ohio
66littlebigmopar Offline
parma,ohio
I built that car about 4 years ago and ended selling it at carlisle a few years ago. I used one of those summit brand exhaust systems and 2 of those J bend pipes to snake it around the leaf springs. Those are 2 1/2" pipes but there should be room forthe 3 inch. I had the springs moved in with 10" keystones n 295/50-15 tires.
Re: A body - Mini tubs/Cal Tracs/stock gas tank ,Tailpipes? [Re: Sixpak] #673877
04/18/10 10:42 PM
04/18/10 10:42 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
That's what my car is.
69 dart
Stock gas tank
Mini tubbed
Tail pipes to the bumper
I custom made them myself.
VERY tight back there, but it's good to go.
I like my trunk!!!!!!!!!!!
Re: A body - Mini tubs/Cal Tracs/stock gas tank ,Tailpipes? [Re: Sixpak] #673878
04/19/10 02:30 AM
04/19/10 02:30 AM
Cab_Burge Online work
Cab_Burge  Online Work
My 1971 Duster has three inch exhaust with a stock gas tank, it has ladder bars and coil over rear suspension. The pipes come off of the fenderwell headers straight back under the rocker panels and then curve around the rear tires and UNDER the rear end hosuing to the 14x3 oval Magnaflow mufflers mounted behind the rear ties bewteen the sub frame and the outer quarter panels. It is fairly quiet in the car until I go to wide open throttle I had the exhaust system jet hot coated black to help hide it, see the picture. The car now has a different set of headers on it that are black also You can't see the ladder bars or rear suspension unless you lay on the ground and look under the car
Re: A body - Mini tubs/Cal Tracs/stock gas tank ,Tailpipes? [Re: 66littlebigmopar] #673879
04/20/10 12:01 PM
04/20/10 12:01 PM
The Swamp
Sixpak Offline OP
Sixpak  Offline OP
The Swamp
Thanks for posting. If you have more pics, please post them here.
Re: A body - Mini tubs/Cal Tracs/stock gas tank ,Tailpipes? [Re: Sixpak] #673880
04/20/10 08:13 PM
04/20/10 08:13 PM
parma,ohio
parma,ohio
Unfortunely the only pics i have are from the dealer that bought it from me at carlisle. All the pics i took while building were with a disposeable camera. Im still behind times with this computer stuff It was a basket case i bought off a kid who got in trouble with a dui and needed money. It had a mild 400, automatic, 3.23 suregrip, i did a rotessiory on it and sprayed it burnt orange. Just a little street car Lol!
Re: A body - Mini tubs/Cal Tracs/stock gas tank ,Tailpipes? [Re: 66littlebigmopar] #673881
04/20/10 08:15 PM
04/20/10 08:15 PM
parma,ohio
parma,ohio
Another
