Rocker Shaft Oiling on a Big Block #673544
04/18/10 10:20 AM
04/18/10 10:20 AM
Illinois
ChrisDavis Offline OP
Illinois
I just put my 400 back together with new hydraulic roller lifters. Now that everything is reassembled I am second guessing myself. I am using regular adjustable shaft mount roller rockers. The shaft gets it’s oil supply from a hole in the shaft that is fed from the second mounting stud from each end.
My question: Is there a top and a bottom to the shaft? Is there an oil supply hole in both sides of the shaft or just one side? Is it possible to install the shaft with the wrong side up and have the oil supply hole face up with the other side of the shaft effectively blocking the oil supply from the head?
Re: Rocker Shaft Oiling on a Big Block [Re: ChrisDavis] #673545
04/18/10 10:33 AM
04/18/10 10:33 AM
The rocker holdown bolt holes in the shaft are the same on both sides so they could be installed upside down and the shaft itself will still recieve oil but you want the small oiling holes where the oil comes out at each rocker on the bottom side of the shaft to be slightly offset toward the valve side. If the notch on the front of the drivers side shaft is down and the notch on the rear of the passenger side shaft is down you are good
Re: Rocker Shaft Oiling on a Big Block [Re: ChrisDavis] #673546
04/18/10 10:53 AM
04/18/10 10:53 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Not all shafts are the same. None the less, there are four different orientations for installing a shaft, and generally, only one orientation is correct.
Re: Rocker Shaft Oiling on a Big Block [Re: BSB67] #673547
04/18/10 11:24 AM
04/18/10 11:24 AM
Illinois
Illinois
I will go and pull the valve covers and see where the notches are on each side. I wish I had been paying more attention when I put it togather.
Re: Rocker Shaft Oiling on a Big Block [Re: ChrisDavis] #673548
04/18/10 11:34 AM
04/18/10 11:34 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Notches are small block thing. Just put the 1/8 inch oiling holes down and away from pushrod side of shaft as mentioned.
Re: Rocker Shaft Oiling on a Big Block [Re: buildanother] #673549
04/18/10 11:40 AM
04/18/10 11:40 AM
Illinois
Illinois
Is there any way I can tell by looking at the shaft as opposed to removing it? That’s why I was wondering if the oil feed holes exist on both sides of the shaft. If they do then it wouldn’t matter which side was down.
Re: Rocker Shaft Oiling on a Big Block [Re: ChrisDavis] #673550
04/18/10 12:06 PM
04/18/10 12:06 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
No you cannot tell. No, there are usually only holes on the bottom (depending on who's shaft you're using), and even if they are down, they still may not be in the correct orientation.
They need to come off.
Re: Rocker Shaft Oiling on a Big Block [Re: BSB67] #673551
04/18/10 12:12 PM
04/18/10 12:12 PM
Illinois
Illinois
Can you tell me what you mean by even if the holes are down they might not be in the correct orientation? Are you referring to the shaft possibly being flipped end for end?
I guess I have no choice but to take it apart again. Story of my life! Can you tell me what to look for when I get it apart?
Re: Rocker Shaft Oiling on a Big Block [Re: ChrisDavis] #673552
04/18/10 12:15 PM
04/18/10 12:15 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
To quote RapidRobert's answer. "If the notch on the front of the drivers side shaft is down and the notch on the rear of the passenger side shaft is down you are good"
Re: Rocker Shaft Oiling on a Big Block [Re: ChrisDavis] #673553
04/18/10 12:15 PM
04/18/10 12:15 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
roller rockers are sealed all the way around the shaft unlike stamped so it really matters not which way the holes are. But down is right down and angled back I believe on stock shafts and stamped rockers.
Re: Rocker Shaft Oiling on a Big Block [Re: Dodgem] #673554
04/18/10 12:40 PM
04/18/10 12:40 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
That's kind of what I was thinking.
Re: Rocker Shaft Oiling on a Big Block [Re: Chilort] #673555
04/18/10 12:44 PM
04/18/10 12:44 PM
Illinois
Illinois
OK, I have one valve cover off. There are no notches or markings on the ends of the shaft at all. I believe Buildanother said that only applied to small blocks. I guess I will pull the shaft next. Besides the oil hole facing down what else should I look for to verify the correct orientation of the shaft? I had it running for a while at an idle. There is plenty of oil puddled in the head so it must be oiling somewhat.
Re: Rocker Shaft Oiling on a Big Block [Re: ChrisDavis] #673556
04/18/10 12:56 PM
04/18/10 12:56 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Small block is where there are notches on the shafts that are used as indicators - not on BB's. As stated above.
Hey Prime the engine and if you have oil a good supply you have no problem. Remember that only one side feeds oil at a time depending on camshaft position to the oil gallary.
Re: Rocker Shaft Oiling on a Big Block [Re: MoparforLife] #673557
04/18/10 01:05 PM
04/18/10 01:05 PM
Illinois
Illinois
Thanks. So if I understand correctly as long as my oil holes are facing down and it is getting oil supply then everything is OK? I also assume that if everything seems to be oiling well then the holes must be facing down.
Re: Rocker Shaft Oiling on a Big Block [Re: ChrisDavis] #673558
04/18/10 01:07 PM
04/18/10 01:07 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
ChrisDavis, RR answered your question earlier about orientation.
Dodgem - I'm not sure what you mean by "sealed" but you can probably get away with it on a conventional adgustable rocker with moderate valve spring pressure. If you flip the orientation of the oiling holes and run it for a while, you'll see the misalignment of the oil hole relative to the wear area on the shaft.
Re: Rocker Shaft Oiling on a Big Block [Re: BSB67] #673559
04/18/10 01:21 PM
04/18/10 01:21 PM
Cookeville
Chilort Offline
Chilort  Offline
Cookeville
Dodgem - I'm not sure what you mean by "sealed" but you can probably get away with it ...
If it is just roller tipped and not full roller (i.e. bushed) then the orientation matters. If it is a full roller rocker (i.e. Harland Sharp) then there is a roller bearing all the way around. Where the hole is in the shaft shouldn't matter with a full roller rocker.
Re: Rocker Shaft Oiling on a Big Block [Re: Chilort] #673560
04/18/10 03:15 PM
04/18/10 03:15 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Correct. I'm assuming that he does not have fulcrum rollers. Could be mistaken
Re: Rocker Shaft Oiling on a Big Block [Re: BSB67] #673561
04/18/10 04:06 PM
04/18/10 04:06 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i would pull the shaft ( it takes less than 5 min.) slide one rocker off, if the small oil hole is on the bottom and oriented towards the exhaust side not the intake side you are good. if not, spin the shaft front to back and re place the rocker gear correctly. not that big of a job. then check the other head. should be half hour to an hour and its fun, you get to play with a big block mopar!
Re: Rocker Shaft Oiling on a Big Block [Re: dirtybee] #673562
04/18/10 04:41 PM
04/18/10 04:41 PM
I had no idea BB's didn't have the notches also. I'd as he said pull each shaft/rocker assy, take off 1 rocker and if the holes are not on the bottom/15 deg toward the valve side I'd slide the shaft out and put it back in the other way/reassemble
Re: Rocker Shaft Oiling on a Big Block [Re: RapidRobert] #673563
04/21/10 09:52 PM
04/21/10 09:52 PM
Illinois
Illinois
You know how some days it doesn’t pay to get out of bed? The new Scorpion lifters went in without a hitch. They are quiet too. I did have the shaft in its correct orientation for oiling. However….. I now have a stripped rocker shaft bolt hole. One of the ones that feeds oil. The aluminum is stripped out along with about 70% of the helicoil. I have 4 good threads left at the bottom and have studs, as opposed to bolts, on order. I am thinking maybe JB Weld instead of Locktite.
