Re: Rocker Shaft Oiling on a Big Block
[Re: ChrisDavis]
#673545
04/18/10 10:33 AM
04/18/10 10:33 AM
RapidRobert
The rocker holdown bolt holes in the shaft are the same on both sides so they could be installed upside down and the shaft itself will still recieve oil but you want the small oiling holes where the oil comes out at each rocker on the bottom side of the shaft to be slightly offset toward the valve side. If the notch on the front of the drivers side shaft is down and the notch on the rear of the passenger side shaft is down you are good
[Re: Dodgem]
#673554
04/18/10 12:40 PM
04/18/10 12:40 PM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
roller rockers are sealed all the way around the shaft unlike stamped so it really matters not which way the holes are.
That's kind of what I was thinking.
[Re: ChrisDavis]
#673556
04/18/10 12:56 PM
04/18/10 12:56 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
OK, I have one valve cover off. There are no notches or markings on the ends of the shaft at all. I believe Buildanother said that only applied to small blocks. I guess I will pull the shaft next. Besides the oil hole facing down what else should I look for to verify the correct orientation of the shaft? I had it running for a while at an idle. There is plenty of oil puddled in the head so it must be oiling somewhat.
Small block is where there are notches on the shafts that are used as indicators - not on BB's. As stated above. Hey Prime the engine and if you have oil a good supply you have no problem. Remember that only one side feeds oil at a time depending on camshaft position to the oil gallary.
[Re: BSB67]
#673559
04/18/10 01:21 PM
04/18/10 01:21 PM
Chilort
Cookeville
Dodgem - I'm not sure what you mean by "sealed" but you can probably get away with it ...
If it is just roller tipped and not full roller (i.e. bushed) then the orientation matters. If it is a full roller rocker (i.e. Harland Sharp) then there is a roller bearing all the way around. Where the hole is in the shaft shouldn't matter with a full roller rocker.
[Re: dirtybee]
#673562
04/18/10 04:41 PM
04/18/10 04:41 PM
RapidRobert
I had no idea BB's didn't have the notches also. I'd as he said pull each shaft/rocker assy, take off 1 rocker and if the holes are not on the bottom/15 deg toward the valve side I'd slide the shaft out and put it back in the other way/reassemble
