512 on the hook #672589
04/17/10 01:38 PM
04/17/10 01:38 PM
AndyF Offline OP
AndyF  Offline OP
Finally got back around to this project. Getting ready to drop the 512 back into my street car. I haven't touched this project in a long time. The car has a thick coating of dust on it!
Re: 512 on the hook [Re: AndyF] #672590
04/17/10 02:30 PM
04/17/10 02:30 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Nice! Is that going in the Coronet I've seen a few pics of? Is that a Doug Nash tranny?
Re: 512 on the hook [Re: Bigcube] #672591
04/18/10 12:04 PM
04/18/10 12:04 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Sweet tell us more about the combo. Are you going to run the manifolds too?
Re: 512 on the hook [Re: 70VcodeCoronetRT] #672592
04/18/10 02:55 PM
04/18/10 02:55 PM
AndyF Offline OP
AndyF  Offline OP
Yep, manifolds are a must for me. 512 inch low deck with RB mains, cross bolted main caps, roller bearing camshaft. CNC ported Mopar 452 heads. Callies crank, Crower rods, custom Diamond pistons. Tons of custom stuff, the dang project took me about 5 years. I think the guys at CRE machined this block back in 2005.
Re: 512 on the hook [Re: AndyF] #672593
04/18/10 02:56 PM
04/18/10 02:56 PM
AndyF Offline OP
AndyF  Offline OP
Another view of the motor from the top before it goes into the car.
Re: 512 on the hook [Re: AndyF] #672594
04/18/10 02:57 PM
04/18/10 02:57 PM
AndyF Offline OP
AndyF  Offline OP
Close up of the head pipe on the driver's side. It has to snake around the bellhousing, starter and clutch linkage. Nobody makes 3 inch pipes that work so it all had to be built by hand.
Re: 512 on the hook [Re: AndyF] #672595
04/18/10 02:58 PM
04/18/10 02:58 PM
AndyF Offline OP
AndyF  Offline OP
Oil pump cover is custom made to clear the K frame.
Re: 512 on the hook [Re: AndyF] #672596
04/18/10 03:00 PM
04/18/10 03:00 PM
AndyF Offline OP
AndyF  Offline OP
Here is the rotating assembly. Callies crank with 440 mains, Crower rods and Diamond pistons. The big dish gets the compression down for pump gas.
Re: 512 on the hook [Re: AndyF] #672597
04/18/10 03:01 PM
04/18/10 03:01 PM
AndyF Offline OP
AndyF  Offline OP
Roller bearing camshaft. This wasn't one of my better ideas!
Re: 512 on the hook [Re: Bigcube] #672598
04/18/10 03:04 PM
04/18/10 03:04 PM
AndyF Offline OP
AndyF  Offline OP
Yep, Doug Nash five speed.
Yes, it is going in the Coronet as soon as I clean away the clutter in the shop.
Re: 512 on the hook [Re: AndyF] #672599
04/18/10 06:10 PM
04/18/10 06:10 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Looks tough Andy now get that thing in the car and grab some gears.
Do you have a 3.27 low in that Nash box? My Richmond has the 3.27 and it works well with the 3.54 rear gear.
Gus
64 Plymouth Savoy
Dana 60
Re: 512 on the hook [Re: fourgearsavoy] #672600
04/19/10 12:44 AM
04/19/10 12:44 AM
AndyF Offline OP
AndyF  Offline OP
Doesn't take too long to drop it in the car. Hooking it all up does take a little wrenching though.
Re: 512 on the hook [Re: AndyF] #672601
04/19/10 05:11 AM
04/19/10 05:11 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Looking awesome as always Andy. I'd love to know the number off of that shifter handle.
Re: 512 on the hook [Re: AndyF] #672602
04/19/10 09:14 AM
04/19/10 09:14 AM
Mass.
RO23J71 Offline
RO23J71  Offline
Mass.
Andy, it looks great. One question though, why is the roller cam bearings a bad idea? Not like you to take the time and trouble to do something you don't feel is worth it.
Good luck, Paul
Re: 512 on the hook [Re: AndyF] #672603
04/19/10 09:58 AM
04/19/10 09:58 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good deal, have some fun with that thing!
I'm about ready to get the old nasty GTX out again also.
Re: 512 on the hook [Re: AndyF] #672604
04/19/10 10:52 AM
04/19/10 10:52 AM
AndyF Offline OP
AndyF  Offline OP
I modified my core support so it can be removed. Sure makes pulling the engine a lot faster. With the overhead crane and the carb plate tilter it is literally a 5 minute job. I can remember years ago wrestling an engine hoist around in the driveway for several hours trying to install the engine the first time!
Re: 512 on the hook [Re: AndyF] #672605
04/19/10 02:28 PM
04/19/10 02:28 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Interesting stands the car is on. I might just make a set of those.
Re: 512 on the hook [Re: GomangoCuda] #672606
04/19/10 05:03 PM
04/19/10 05:03 PM
AndyF Offline OP
AndyF  Offline OP
Very handy stands, I use them all the time. Quite safe also when bolted in place as they are basically impossible to tip over.
Re: 512 on the hook [Re: AndyF] #672607
04/19/10 06:37 PM
04/19/10 06:37 PM
Looks good.........That 12.40 needs to be changed to a 10.40........
Wayne
Re: 512 on the hook #672608
04/19/10 08:51 PM
04/19/10 08:51 PM
AndyF Offline OP
AndyF  Offline OP
Well making down the quarter mile has never been a big priority with me. This car has big brakes, big anti-sway bar up front, big torsion bars, etc. It isn't designed for drag racing but it does have enough power to do okay.
