big block water pump bolts leaking #671991
04/16/10 11:45 PM
04/16/10 11:45 PM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
When I put my new factory style pump in my 440 Source housing I put aviation sealer (baby poop)on the bolts before I installed them. My pump started leaking around the water pump to housing bolts today what do you guys use fo sealer on the bolts? silicone or ????
Re: big block water pump bolts leaking [Re: Boise Chall] #671992
04/17/10 12:56 AM
04/17/10 12:56 AM
Might use some permatex #1 that comes in a small tube. It is viscous and dries hard. Clean the bolt holes, the bolts and let it set up overnight. this area is rarely a problem so check the fit of the bolts into the threads dry ahead of time & see if they feel tight & if so goop em up & install. The thread fit concerns me more than the type of gasket cement
Re: big block water pump bolts leaking [Re: RapidRobert] #671993
04/17/10 01:21 AM
04/17/10 01:21 AM
Boise Idaho
Boise Idaho
After looking at the bolts it doesn't look like the baby poop dried completely it was still tacky when I took the bolts out I wonder if the jar went bad it was pretty old. the pumps been in for about 2 weeks but I only drove the car twice since it's been in and not for very long each time. The pump I took out never leaked at the bolts and used the same bolts so I don't think it's the threads in the housing. I will try the permatex #1 in the morning unless you can think of something that will dry faster I want to drive the car tomorrow.
Re: big block water pump bolts leaking [Re: Boise Chall] #671994
04/17/10 01:35 AM
04/17/10 01:35 AM
Same housing same 4 bolts just a new WP itself? yes goop em up w something thick, I'd drain some of the coolant clean the holes/bolts w some starting fluid (it flashes off in seconds), use the Permatex #1 and fire it up.
Re: big block water pump bolts leaking [Re: RapidRobert] #671995
04/17/10 07:51 AM
04/17/10 07:51 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just use some liquid teflon.Ive never had a leak using it.Rocky
Chrysler Firepower
