8&3/4 end play problem
#671873
04/16/10 10:00 PM
04/16/10 10:00 PM
RapidRobert
SBP 8&3/4 going together and I cant get one axle in all the way, lacking ~1/4 or so. (open chunk). w the chunk out & it mocked up w the backing plates on (& no foam or steel shims) and the axles in I have exactly 1&9/32" between the splined ends but even them I have to pound the axles in which I am not comfortable with. pull apart/add chunk/reassemble axles/b plates I have the ~1/4 I cant get in. The housing is 52&5/8" and it feels like I'm hitting solid metal. Thank you for your time.
Re: 8&3/4 end play problem
[Re: scratchnfotraction]
#671875
04/16/10 10:23 PM
04/16/10 10:23 PM
RapidRobert
No michael I for some reason forgot all about adjusting the adjuster till I got inside but with that much left to go sumpin ain't kosher plus the bearings are just too tight going in
[Re: moparcyco]
#671878
04/17/10 12:39 AM
04/17/10 12:39 AM
RapidRobert
I drove one seal in and had the prob and I whacked it again and it felt like that it was in all the way. The axle is seated (you can feel the ring of the metal when you hit it but it wont go in) and all of the bearing is not into the housing
[Re: RapidRobert]
#671879
04/17/10 10:07 AM
04/17/10 10:07 AM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
the thrust spacer in an 8-3/4 is 1-1/2" wide so 1-1/2 minus 1-9/32 would give you 7/32"(or nearly the 1/4" that you are having trouble with.)
[Re: 446acuda]
#671882
04/17/10 10:33 AM
04/17/10 10:33 AM
RapidRobert
Alright bro I am going to go get on it. Thank you for your help and I'll check the one seal that is in there 1st
