Unusual brake behavior (updated)
#67150
06/04/08 12:38 AM
06/04/08 12:38 AM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
So I got my new brakes buttoned up tonight. Wilwood fronts on my '71 Demon, stock 9" drums in the rear. I bled each of the Dynalite calipers in the front from the two upper bleeders, but not the bottom two on each, if that makes a difference.
I also set the Wilwood adjustable prop valve to counterclockwise, which Wilwood says is full pressure to the calipers, and both the prop valve and the residual valve (10lb) are in the rear brake line circuit.
I drove it out of the driveway, and it seemed like the pads were a little close to the rotor, so I had to give it some gas. Well, I go to make my first hard stop (at around 15mph), and it stopped pretty good. The problem I am having, is that when I let off the brake pedal (I know the piston comes all the way back in the MC as well), even if I'm in first gear, the car doesn't want to start going again. I have to give it gas for it to start moving like it's in drive. Any guesses as to why it's doing this? Thanks.
I was thinking I might try backing off the pressure on the calipers incrementally, but I don't know that it would help the after-braking problem?
Re: Unusual Wilwood behavior
[Re: sharpie]
#67154
06/04/08 05:26 PM
06/04/08 05:26 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
Re: Unusual brake behavior (updated)
[Re: sharpie]
#67155
06/04/08 11:01 PM
06/04/08 11:01 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
update: I adjusted the prop valve with no luck today. I put it at max pressure in the rear with no luck and then put it at a midpoint. Still nothing. I do, however, see a new problem. I can let the car idle, and it will start going a bit faster than last time, but now after maybe 100 feet, it starts to actually slow down when idling to less than 2mph. I haven't changed anything except the brakes since I drove it before the brake change. Any ideas? Also, on an unrelated note, I had cranked up the torsion bars (clockwise) to keep the wheel wells away from the tires. We're talking a good seven threads or more. It looked fine after I finished, but one trip around the block, and it settled back to where it was before, almost precisely. I am confused.
[Re: sharpie]
#67156
06/05/08 06:22 PM
06/05/08 06:22 PM
Posts: 6,516 Santa Cruz, California
Lefty
I don't quite understand the "gap". Am I measuring from inside the pushrod where it meets the piston, or what?
Yes, it's the gap between the pushrod that goes through the firewall and pushes the master cylinder piston. It should not be pushing in the MC piston when the pedal is at rest. If you don't have any gap the MC may be applying the brakes all the time.
You can also crack open the caliper bleeder screw to see if the caliper has fluid pressure all the time. If the rotor turns easier after cracking the bleeder you know it's a fluid pressure problem.
[Re: Lefty]
#67157
06/05/08 11:19 PM
06/05/08 11:19 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
alright, a little more of an update: checked the front calipers, no pressure in them when the brake isn't applied, which is good. I also checked the pushrod, and it was loose (loctite'd it down and lock washered it), but seemed to be coming all the way out. But even after tightening it, it's still doing the same thing. I am however noticing that when I slam the brakes (as if in a hard situation), it does not want to start moving after I take the foot off the brake (auto in 'D'). I also noticed something else. Again I tried to correct the camber a bit by cranking the torsion bars up. I got it to a good place, bounced on the hood/bumper to settle it, and it was still good. I drove it around the block and while I was driving, I could see it, the suspension settled down again to where it was before cranking it. But the torsion bar adjusting bolts are still in a position which should show the suspension cranked up. I am so confused...
[Re: sharpie]
#67158
06/05/08 11:37 PM
06/05/08 11:37 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
Interesting - I've had no problem like that but my setup's a little different. I have: Wilwoods front disc setup for 10" drum spindels, manual Rear 11" drum brakes off a 74 van Wilwood prop valve Modern-style aluminum master cylinder Are you sure the rears aren't still holding? I'd remove the residual valve and try a test drive that way, I have no resdiual valve in my set up. It may be too much for the small 9" drums.
Ride eternal, shiny and chrome
[Re: sharpie]
#67161
06/06/08 12:34 PM
06/06/08 12:34 PM
Posts: 32,922 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Have you checked the rear brakes yet? BTW "pads to close to the shoe" ??? The pads normally rub slightly on the rotors. The rear shoes should just barely touch the drums. When adjusting them you are good when you hear the shoes starting to rub while truning the drum.
[Re: stumpy]
#67162
06/06/08 06:23 PM
06/06/08 06:23 PM
Posts: 329 Cincinnati, OH
68red440
Cincinnati, OH
I've got a very similar problem. SSBC front disc conversion, 10" rr drums My MC, prop valve, and set-up is the same as your Wilwood. Does your pedal return properly? Mine doesn't. My story is long and complicated, but something I noticed is after I pull the drums and do anything with the rear brakes, the next time I drive it, the pedal returns properly for the first several stops. Then the pedal starts to stick again. I've pulled the MC apart, checked the pushrod length, checked for mechanical binding, etc. Something is going on with the rear brakes. I think we need to better understand the residual valve(s) in the system. The SSBC rep has been very helpful. I'll let you know if I learn anything new.
