Brake Pedal not coming back up #671410
04/16/10 12:15 PM
04/16/10 12:15 PM
Oklahoma
N
Nick Offline OP
Nick  Offline OP
N
Oklahoma
I am having a problem with the brake peddle not coming back up. Power Brakes, brakes stop car. Any ideas?
Thanks!
__________________________________________________
[color:"Blue"]
1970 Charger R/T
1970 Barracuda
1971 Barracuda
1973 Duster 440
1974 Sattelite
[/color]
Re: Brake Pedal not coming back up [Re: Nick] #671411
04/16/10 12:19 PM
04/16/10 12:19 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I had the same problem on my Charger. IIRC it was the rod going into the master cylinder that needed adjusting. Might want to check your return spring also.
Re: Brake Pedal not coming back up [Re: JoesMopar] #671412
04/16/10 01:05 PM
04/16/10 01:05 PM
Oklahoma
N
Nick Offline OP
Nick  Offline OP
N
Oklahoma
Thanks, I'll give it try. I am actually redoing the whole brake system, lines, calipers, etc, but I checked it after replacing a couple parts and it was still staying done.
Maybe that will do it. Thanks again.
[color:"Blue"]
1970 Charger R/T
1970 Barracuda
1971 Barracuda
1973 Duster 440
1974 Sattelite
[/color]
Re: Brake Pedal not coming back up [Re: Nick] #671413
04/16/10 02:33 PM
04/16/10 02:33 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Thanks!
The only time I've seen that is when the MC is rusted inside.
Re: Brake Pedal not coming back up [Re: Lefty] #671414
04/16/10 02:42 PM
04/16/10 02:42 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Nick, make sure your pivot bolt that bolts the mastercylinder rod to the pedal DOES allow the mastercylinder rod to "pivot". It can't be tightly clamped to the pedal.
Jess
Yeah, it's hopped up to over 160...
Re: Brake Pedal not coming back up [Re: jt4406] #671415
04/16/10 03:21 PM
04/16/10 03:21 PM
Oklahoma
N
Nick Offline OP
Nick  Offline OP
N
Oklahoma
Thanks Lefty. I did just put a new master cylinder on it. That was my first guess at it, but same result.
Jess, Didn't pay attention to the rod when I replaced the Master cylinder. I'll check it out.
[color:"Blue"]
1970 Charger R/T
1970 Barracuda
1971 Barracuda
1973 Duster 440
1974 Sattelite
[/color]
Re: Brake Pedal not coming back up [Re: Nick] #671416
04/16/10 04:21 PM
04/16/10 04:21 PM
When you split the m/c and booster to check the clearance, start it & push the pedal & see if it now returns OK
