Brake Pedal not coming back up
#671410
04/16/10 12:15 PM
04/16/10 12:15 PM
Posts: 7 Oklahoma
Nick
Oklahoma
I am having a problem with the brake peddle not coming back up. Power Brakes, brakes stop car. Any ideas?
Thanks!
__________________________________________________ [color:"Blue"] 1970 Charger R/T 1970 Barracuda 1971 Barracuda 1973 Duster 440 1974 Sattelite [/color]
Re: Brake Pedal not coming back up
[Re: JoesMopar]
#671412
04/16/10 01:05 PM
04/16/10 01:05 PM
Posts: 7 Oklahoma
Nick
Oklahoma
Thanks, I'll give it try. I am actually redoing the whole brake system, lines, calipers, etc, but I checked it after replacing a couple parts and it was still staying done.
Maybe that will do it. Thanks again.
[Re: Nick]
#671413
04/16/10 02:33 PM
04/16/10 02:33 PM
Posts: 6,516 Santa Cruz, California
Lefty
Thanks!
The only time I've seen that is when the MC is rusted inside.
[Re: Lefty]
#671414
04/16/10 02:42 PM
04/16/10 02:42 PM
Posts: 1,567 Ky
jt4406
Ky
Nick, make sure your pivot bolt that bolts the mastercylinder rod to the pedal DOES allow the mastercylinder rod to "pivot". It can't be tightly clamped to the pedal. Jess
Yeah, it's hopped up to over 160...
[Re: jt4406]
#671415
04/16/10 03:21 PM
04/16/10 03:21 PM
Posts: 7 Oklahoma
Nick
Oklahoma
Thanks Lefty. I did just put a new master cylinder on it. That was my first guess at it, but same result.
Jess, Didn't pay attention to the rod when I replaced the Master cylinder. I'll check it out.
[Re: Nick]
#671416
04/16/10 04:21 PM
04/16/10 04:21 PM
RapidRobert
When you split the m/c and booster to check the clearance, start it & push the pedal & see if it now returns OK
