What to do with seatbelt and seatback when mini-tubbing #671394
04/16/10 11:56 AM
04/16/10 11:56 AM
Denver
E
Explodo Offline OP
Explodo  Offline OP
E
Denver
I'd like to mini-tub my '67 Satellite and I'd also like to keep the back seat. The rear seatbelts anchors in that strip of metal between the inner wheelhouse and the frame. In addition, the rear seatback is up against the inner wheelhouse. What have others done to keep these items? What's a safe location to relocate the seatbelt anchor to? How should I make the seatback fit? Any information would be greatly appreciated.
'67 440 Satellite
Re: What to do with seatbelt and seatback when mini-tubbing [Re: Explodo] #671395
04/16/10 10:35 PM
04/16/10 10:35 PM
Denver
E
Explodo Offline OP
Explodo  Offline OP
E
Denver
(bump) Someone must know something about this.
'67 440 Satellite
Re: What to do with seatbelt and seatback when mini-tubbing [Re: Explodo] #671396
04/17/10 12:07 AM
04/17/10 12:07 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I'm not familiar with the B minitub issues. I did this on an A body. Maybe you can do something similar.
Re: What to do with seatbelt and seatback when mini-tubbing [Re: RobX4406] #671397
04/17/10 02:28 AM
04/17/10 02:28 AM
Denver
E
Explodo Offline OP
Explodo  Offline OP
E
Denver
On a 67 b-body, the rear seatback sits against the side of the stock wheelhouse location. If you move it over a couple of inches, you'd have to maybe bend up the seat frame? That's what I'm wondering about. In addition, the outer seatbelt anchor points are in the strip of metal between the wheelhouse and the framerail that's going to be removed...so it has to be relocated somewhere. Where do folks put that?
'67 440 Satellite
Re: What to do with seatbelt and seatback when mini-tubbing [Re: Explodo] #671398
04/17/10 09:02 AM
04/17/10 09:02 AM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
My car is minitubbed and I still have the back seat. I did not do the work, but the seat frames were bent to clear the new wheel wells and it works OK. The outside seat belt mounts are gone, but I suppose they could be moved to re-mount them. I just have one center belt.
If you have tools & torch, go ahead and relocate them.
Re: What to do with seatbelt and seatback when mini-tubbing [Re: hydro] #671399
04/17/10 10:36 AM
04/17/10 10:36 AM
Denver
E
Explodo Offline OP
Explodo  Offline OP
E
Denver
Thank you.
'67 440 Satellite
