Re: Norwalk Sunday....I'll be there!
[Re: tboomer]
#670762
04/15/10 08:54 PM
04/15/10 08:54 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Sweet, I'ld love to see ya again.
I have my chassis cert appt at 10:30 Sun morn. I just hope I need it ![](/ubbthreads/images/graemlins/laugh2.gif)
If you want, you could swing by my pit and post your new best before you leave
[Re: WILD BILL]
#670763
04/15/10 09:00 PM
04/15/10 09:00 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
Lets not get ahead of ourselves just yet. ![](/ubbthreads/images/graemlins/tsk.gif)
[Re: wheelsup68dart]
#670764
04/15/10 09:15 PM
04/15/10 09:15 PM
WILD BILL
BROOK PARK, OH
OK,
If you get a new best, your more than welcome to stop by and post it. ![](/ubbthreads/images/graemlins/biggrin.gif)
I'm bettin it'll be when not if
[Re: 360904]
#670766
04/16/10 07:59 AM
04/16/10 07:59 AM
Posts: 422 nw pa
steelhead
nw pa
[Re: dartman366]
#670770
04/20/10 02:50 PM
04/20/10 02:50 PM
wheelsup68dart
Columbus, Ohio
It was'nt good ![](/ubbthreads/images/graemlins/down.gif) I di find that the car drives straight and the motor is gonna make some serious steam, but had major trans problems right off the bat, suspect the valve body or converter is bad. Here was the numbers from best pass. 1.657 60' 4.3? 330 6.50 660 @ 111 10.11 1320 @ 134 Car sould not hold apply on low gear and crawled out of the hole. I am thinking that if every .01 in 60' is worth .02 at stripe then I will be really happy when low gear is fixed. Would figure 9.20's may be attainable. Chassis did pass recert and everything else that was done at BG's is great. Will probably get out again before Columbus CC, but who knows? Will also likely have the 1050 Dominator going on at that event. ![](/ubbthreads/images/graemlins/biggrin.gif)
#670771
04/20/10 03:54 PM
04/20/10 03:54 PM
WILD BILL
BROOK PARK, OH
WIll the bowl gaskets work with with the dommy? ![](/ubbthreads/images/graemlins/biggrin.gif)
Sounds like you and I might be in the same boat.
[Re: tboomer]
#670775
04/20/10 09:35 PM
04/20/10 09:35 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Sorry to hear about the bad outing Lonnie. Is that the same trans from last year? If you do need a trans done at a reasonable price you should check with Mike Karas up here. If you need his number or anything else give me a Great to hear the car went nice and straight ![](/ubbthreads/images/graemlins/thumbs.gif) BGR did my cage and set up the rear and tied it all together real nice and mine is sweet too ![](/ubbthreads/images/graemlins/bow.gif) Russ
