Re: GTX won't start...ran yesterday!
[Re: Dirk]
#669887
04/14/10 10:23 PM
04/14/10 10:23 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Ballast resistor,if you have one. Bulkhead connection.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: Dirk]
#669888
04/14/10 11:37 PM
04/14/10 11:37 PM
RapidRobert
You mentioned restoration so I am assuming points. w your test light see if it has fire to the coil positive primary terminal while someone turns the key to start then check if the coil negative primary terminal blinks off/on also when someone turns the key to start. Can (temporarily) disable the starter at the starter relay while you are doing this testing as to not run the batt down for no good reason cause you are not concerned w the cranking circuit. If no fire work backward to the bulkhead and inside if necc. EDIT forgot, for the neg side to blink the starter will have to crank it over.
[Re: 6bblFLASH]
#669890
04/15/10 10:40 AM
04/15/10 10:40 AM
Posts: 3,482 Cold Spring, NY
1970GTX
Cold Spring, NY
I went through this the other day. Vermin got into the engine compartment and knocked the connector off of the ballast resistor. plugged it back in and it fired right up.
[Re: 1970GTX]
#669891
04/15/10 05:24 PM
04/15/10 05:24 PM
Posts: 24 Oregon
Dirk
Cleaned up the bulkhead connectors, checked all connections under dash, changed the ignition switch. What kind of voltages should I get at each end of the ballast resister on the firewall?
