Bronze Oil Pump Gear And Shaft.... #669434
04/14/10 07:58 AM
04/14/10 07:58 AM
tboomer Offline OP
tboomer  Offline OP
Took today off work so I could get a bunch of parts ordered....Among those is the bronze gear and shaft...Looks like the choice is MP,Milodon or 440 Source....Also have to order a good 3 bolt timing chain for the roller....Any suggestions,guys?? Thanks!! Ted
Re: Bronze Oil Pump Gear And Shaft.... [Re: tboomer] #669435
04/14/10 08:27 AM
04/14/10 08:27 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
You didn't lose the info I sent you on the chain did you
Re: Bronze Oil Pump Gear And Shaft.... [Re: tboomer] #669436
04/14/10 08:29 AM
04/14/10 08:29 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
for the timing chain i have a cloyes with 3 keyway.how much adjusting do you think you will do on the cam?
Re: Bronze Oil Pump Gear And Shaft.... [Re: blownzoom440] #669437
04/14/10 08:32 AM
04/14/10 08:32 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Ask Scott about Taylor's cam
Re: Bronze Oil Pump Gear And Shaft.... [Re: blownzoom440] #669438
04/14/10 08:35 AM
04/14/10 08:35 AM
tboomer Offline OP
tboomer  Offline OP
Bill....I lost it...Mike...Hope we don't adjust much...This damn 383 is getting expensive!!
Re: Bronze Oil Pump Gear And Shaft.... [Re: tboomer] #669439
04/14/10 08:38 AM
04/14/10 08:38 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I'll try and dig it up as soon as I get my laptop back from the repair shop today
Re: Bronze Oil Pump Gear And Shaft.... [Re: WILD BILL] #669440
04/14/10 08:39 AM
04/14/10 08:39 AM
tboomer Offline OP
tboomer  Offline OP
OK.....I was telling Vern how this little 383 is putting a scare to ya!!
Re: Bronze Oil Pump Gear And Shaft.... [Re: tboomer] #669441
04/14/10 08:52 AM
04/14/10 08:52 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Dam dude, it's in your "Pete Jackson Gear Drive" post
I can't link it till I get my lap top back but just search it using my user name
Re: Bronze Oil Pump Gear And Shaft.... [Re: WILD BILL] #669442
04/14/10 08:53 AM
04/14/10 08:53 AM
tboomer Offline OP
tboomer  Offline OP
Thanks!! So....Are you scared yet?? We both will probably pee our pants!!
Re: Bronze Oil Pump Gear And Shaft.... [Re: tboomer] #669443
04/14/10 09:26 AM
04/14/10 09:26 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
When I could not afford a gear drive. I went with a timing chain from Indy it does look like a nice timing chain.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Bronze Oil Pump Gear And Shaft.... [Re: MRMOPAR622] #669444
04/14/10 09:31 AM
04/14/10 09:31 AM
tboomer Offline OP
tboomer  Offline OP
Thanks....I have also heard that is a nice chain...Did it come with everything for a roller cam?
Re: Bronze Oil Pump Gear And Shaft.... [Re: tboomer] #669445
04/14/10 11:03 AM
04/14/10 11:03 AM
iowa
bad1970dust Offline
"Hollywood"
bad1970dust  Offline
"Hollywood"
iowa
ted get off the dam computer and get me some parts for this thing. so you can make the first race. iam looking for a first round duck !!!
Re: Bronze Oil Pump Gear And Shaft.... [Re: tboomer] #669446
04/14/10 11:19 AM
04/14/10 11:19 AM
State of Fascism
52savoy Online content
52savoy  Online Content
State of Fascism
RollMaster and Cloyes are both pretty good choices. A dual idler set-up works good too and the price has come down a lot. Less than a $100.
Re: Bronze Oil Pump Gear And Shaft.... [Re: bad1970dust] #669447
04/14/10 11:42 AM
04/14/10 11:42 AM
tboomer Offline OP
tboomer  Offline OP
You will get your duck... I am waiting on a couple of phone calls before I pull the trigger...
Re: Bronze Oil Pump Gear And Shaft.... [Re: tboomer] #669448
04/14/10 01:04 PM
04/14/10 01:04 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
A 509 purple shaft does not require a bronze gear
Re: Bronze Oil Pump Gear And Shaft.... [Re: ZIPPY] #669449
04/14/10 01:28 PM
04/14/10 01:28 PM
tboomer Offline OP
tboomer  Offline OP
Hi,Zippy! Look up DCC3690876 for me...I think that is the shaft I need...
Re: Bronze Oil Pump Gear And Shaft.... [Re: tboomer] #669450
04/14/10 01:35 PM
04/14/10 01:35 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Hey Ted,
don't forget to put a cam button in there also.
Russ
Re: Bronze Oil Pump Gear And Shaft.... [Re: old_racer] #669451
04/14/10 01:38 PM
04/14/10 01:38 PM
tboomer Offline OP
tboomer  Offline OP
Yupp!! Which one,Russ?? Also is there some bearing to order?
Re: Bronze Oil Pump Gear And Shaft.... [Re: tboomer] #669452
04/14/10 01:46 PM
04/14/10 01:46 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Ted,
some use the bearing type other's the alum button , I've used both, you have to mock up your front cover and water pump housing together to see what clearance you have with either. I think they are the same as the big block chebby.
Russ
Re: Bronze Oil Pump Gear And Shaft.... [Re: tboomer] #669453
04/14/10 01:54 PM
04/14/10 01:54 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
that's the one for a Milodon pump. they're finally back in Mopar warehouse stock again, along with the 875 "normal" length one.
I guess I'll stop with the purple shaft comments
Rich H.
Esse Quam Videri
