rear end----68 b-Body vs truck width #668861
04/13/10 03:10 PM
04/13/10 03:10 PM
Bethlehem Pa.
tinman68 Offline OP
tinman68  Offline OP
Bethlehem Pa.
Is the width of a 68 b-body rear the same as a truck rear???
if not whats the difference????
will the leaf springs line up w/the plates and pins
I took rear to local shop and I'm wandering if they could have switched it out on me.
put on new super stock leaf springs w/275-60-15 tires on 10" wheels and tires rub pretty bad..
Re: rear end----68 b-Body vs truck width [Re: tinman68] #668862
04/13/10 04:35 PM
04/13/10 04:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: rear end----68 b-Body vs truck width [Re: tinman68] #668863
04/13/10 04:37 PM
04/13/10 04:37 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
a 68 B rear should be 60 1/8 wide with 43" pads..
a truck rear
65-71 61 13/16
72-74 64 3/8 0n 44" pads
I am truckless..
Re: rear end----68 b-Body vs truck width [Re: 340SHORTY] #668864
04/13/10 04:50 PM
04/13/10 04:50 PM
scratchnfotraction Offline
A-body and truck share the 43" spring center
IIRC the 68 B-body housing would have 44" spring centers
the springs on an A-body will spred enuff to use the B-body rear with 44" pads
the C-body 8 3/4 is the same width as a truck 8 3/4...59" flange to flange, but the spring centers are diff on the C-body housing
I cant figure the 8 3/4- 55" flange to flange with 46" spring centers I have..its a 67 B -body I thought but told a 67 polara was a c-body
also was told its a E-body housing
the axles are 30"
did the axle and tire combo fit before the shop work???
Re: rear end----68 b-Body vs truck width [Re: scratchnfotraction] #668865
04/13/10 09:49 PM
04/13/10 09:49 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Truck won't directly interchange with a car diff no matter how close the widths are.
The perches are on the wrong side of the axle housing.
I've seen C body diffs stuck in B's,then have tire clearance issues.
Re: rear end----68 b-Body vs truck width [Re: scratchnfotraction] #668866
04/15/10 02:20 AM
04/15/10 02:20 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Oh come on! What kind of hack would try to bend the springs to fit?
Re: rear end----68 b-Body vs truck width [Re: Kern Dog] #668867
04/15/10 10:27 AM
04/15/10 10:27 AM
me,I have done a few
they dont bend they spred some with the rubber bushing enuff to bolt in
its only 1/2" - 1/4" each side
lost less work hassle of cuting welding buy new perches
shadetree hickabilly baby here
