upper control arm bushing install problem #668813
04/13/10 02:14 PM
04/13/10 02:14 PM
Buffalo NY
fourforty Offline OP
Buffalo NY
Hi, I am redoing the front end on a 69 super bee and bought a suspension kit that included polyurethane upper control arm bushings. Problem is they do not appear to fit easily. The upper control arm inside diameter is 1.045 and the bushing outside dia is 1.175, I destroyed one shell trying to press it in. Thought about using a brake cylinder hone to open up the control arms. I think the bushing , which is from energy suspension, measures the same as a factory one, But 0.130 inch difference in size is tough to put together. Any ideas as to what I am missing.
Thx
Al
Re: upper control arm bushing install problem [Re: fourforty] #668814
04/13/10 04:48 PM
04/13/10 04:48 PM
They sent the wrong bushings. Ran into that once & there's 2 different sizes of them. There's no way they'll fit.
Re: upper control arm bushing install problem [Re: fourforty] #668815
08/01/13 01:03 AM
08/01/13 01:03 AM
N. of New Orleans
493 70 Runner Offline
N. of New Orleans
Al,
Did you resolve this issue?
I have similar problem, energy suspension black bushings 5.31125 shells ruined trying to install into new mopar upper control arms.
Re: upper control arm bushing install problem [Re: fourforty] #668816
08/01/13 01:45 AM
08/01/13 01:45 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Put them in the freezer for a few days before installing them, the cold will shrink them
Re: upper control arm bushing install problem [Re: DAYCLONA] #668817
08/01/13 02:08 AM
08/01/13 02:08 AM
N. of New Orleans
N. of New Orleans
Thanks Mike, will do, I used that method with my pilot bushing and did not consider it for this.
