W2 to standard A header adapters... #668114
04/12/10 12:38 PM
04/12/10 12:38 PM
Finally a HUSKER again
Moparnut426 Offline OP
Do you guys remember who made these, and better yet where to find them? I had a set on my old W2 heads, and sold them with the heads, DUMB ME!!
Any help...
Kasey
Re: W2 to standard A header adapters... [Re: Moparnut426] #668115
04/12/10 12:55 PM
04/12/10 12:55 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Hedman makes them.
Re: W2 to standard A header adapters... [Re: rt66jim] #668116
04/12/10 01:29 PM
04/12/10 01:29 PM
RT66JIM,
Do ya by chance have a part number? I have been digging through the headman web site, cant find them.
Kasey
Re: W2 to standard A header adapters... [Re: Moparnut426] #668117
04/12/10 01:39 PM
04/12/10 01:39 PM
Re: W2 to standard A header adapters... [Re: Moparnut426] #668118
04/12/10 02:17 PM
04/12/10 02:17 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
no those are the inner flanges for the econo heads with the narrower bolt pattern..
W2 narrow heads (cc 4 in.). D-port.
Still have the D port shape which is a W2 exhaust port.
Tony
70 AARCuda Vitamin C
Re: W2 to standard A header adapters... [Re: 70AARcuda] #668119
04/12/10 02:51 PM
04/12/10 02:51 PM
My heads are the Brodix heads with the stock 4" cc bolt pattern, I need to go from the stock to the W2/W5 header pattern so I need to make an adapter to go from narrow cc to the wide cc.
The Brodix head uses the D port just like the W2 exhaust.
Kasey
Re: W2 to standard A header adapters... [Re: Moparnut426] #668120
04/12/10 07:45 PM
04/12/10 07:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My Headmans came with adapter plates for W-2 to 4 bolt header flange. I believe I still have one if you need it. If it's the right one at least you would have a template. My headers are 2" A-Body Headmans that have 1 tube thru the inner fender.
Doug
Re: W2 to standard A header adapters... [Re: Moparnut426] #668121
04/12/10 07:51 PM
04/12/10 07:51 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I might have some of these in the garage. I bought them from a member a few years back and never used them. I will get back with you.
68 Barracuda Formula S 340
Re: W2 to standard A header adapters... [Re: Bad340fish] #668122
04/12/10 07:56 PM
04/12/10 07:56 PM
Great guys!
If ya want to sell them, Ill buy them from ya. I would really like that.
Kasey
Re: W2 to standard A header adapters... [Re: Moparnut426] #668123
04/12/10 08:00 PM
04/12/10 08:00 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i have a set of 1 7/8 hedman header i would like to use on standard heads...
could someone make them ?
Tony
Re: W2 to standard A header adapters... [Re: 70AARcuda] #668124
04/12/10 08:06 PM
04/12/10 08:06 PM
Well 70aar...
I made some adapters out of aluminum, and I could make a set for ya out of either aluminum or steel. Just get me a paper, or cardboard template of both header flanges. Its a lot of work, and I know they were made for my head set up otherwise Ill just make my own if I cant get a hold of a set.
Kasey
Re: W2 to standard A header adapters... [Re: 70AARcuda] #668125
04/12/10 10:02 PM
04/12/10 10:02 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My 2" are on standard heads. Made the plates out of 5/16" steel. Traced both sets of gaskets for hole locations and milled the exhaust port holes. Drilled and tapped the header holes. Mounted the plates to the heads with tapered 45 degree allen head bolts. Been on the car 20 years.
Doug
Re: W2 to standard A header adapters... [Re: dvw] #668126
04/12/10 10:07 PM
04/12/10 10:07 PM
If I cant get some already made, thats what Im gonna do.
Re: W2 to standard A header adapters... [Re: Moparnut426] #668127
04/12/10 10:15 PM
04/12/10 10:15 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I had some. Dont remember if i sold them with the heads or not. Can check if you still need some? Carl
Re: W2 to standard A header adapters... [Re: 727builder] #668128
04/12/10 10:19 PM
04/12/10 10:19 PM
Cool if ya have them Id be interested.
Re: W2 to standard A header adapters... [Re: Moparnut426] #668129
04/12/10 10:24 PM
04/12/10 10:24 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Let me go out in the garage and look for them.
BRB
Re: W2 to standard A header adapters... [Re: 727builder] #668130
04/12/10 10:41 PM
04/12/10 10:41 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Will these do you any good? I Ran these back in 1985. Man i'm getting old.
Re: W2 to standard A header adapters... [Re: 727builder] #668131
04/12/10 10:44 PM
04/12/10 10:44 PM
Were those standard to W2, I cant tell off the picture?
Thats what I need is the Standard to W2
If so How much?
PM Me if ya would.
Kasey
Re: W2 to standard A header adapters... [Re: Moparnut426] #668132
04/12/10 10:53 PM
04/12/10 10:53 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
here is a set that I made for a brodix small block head there are aluminum adaptor plates making it into a sthal kind of pattern
Re: W2 to standard A header adapters... [Re: NoFrills] #668133
04/12/10 10:57 PM
04/12/10 10:57 PM
No frills, Do ya have any more pictures of those? Im in the process of buying a set of W5 TTIs, and Thats exactly what Im needing. My brodix heads like yours have standars spread, and I need to do Exactly what ya have there.
Thanks by the way.
Kasey
