Re: Mannn i hate my carrr! jk
[Re: erick72]
#667820
04/12/10 08:49 AM
04/12/10 08:49 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
If you have 11's coming out of the ballast it should still be 11's when it gets to the coil. I would assume the wire ( ballast to coil) is broken and or cooked. It is 37 years old run a test wire straight from the ballast to the + on the coil minimum 12
[Re: Dodgem]
#667821
04/13/10 02:48 AM
04/13/10 02:48 AM
Posts: 902 Seattle, WA
rss
Seattle, WA
He said he's got 11s to the ballast resistor, not coming out of it. Voltage coming out of resistor should be lower since it is after all going through a resistor.
Check out this thread
https://board.moparts.org/ubbthreads/show...rue#Post5237155
[Re: erick72]
#667822
04/13/10 10:14 AM
04/13/10 10:14 AM
RapidRobert
mid 11 volts to the Ballast/2.8 @coil as said if the wire/connections from the ballast "out" downstream to the coil positive are good then the ballast is bad/dropping the voltage too much but I've got a feeling that isn't the case
[Re: RapidRobert]
#667823
04/13/10 12:05 PM
04/13/10 12:05 PM
rss
Seattle, WA
Could you please clarify in English?
[Re: rss]
#667824
04/13/10 12:27 PM
04/13/10 12:27 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Mid 11 volts to the Ballast/2.8 at the coil.
As said, if the wire/connections from the ballast "out" downstream to the coil positive are good, then the ballast is bad/dropping the voltage too much.
I've got a feeling that isn't the case.
[Re: donbarnes]
#667827
04/13/10 05:57 PM
04/13/10 05:57 PM
RapidRobert
Eric w your voltmeter w it at a fast idle put the neg lead on the batt neg post and start checking voltages at every point starting at the battery positive post then to the starter relay then stick a thin probe into the bulkhead terminal & check it's voltage then on the other side of the bulkhead "out" to the ballast, check both sides then see what you have at the coil positive and if it's 2.8V it would not be firing.
[Re: dvw]
#667832
04/13/10 11:20 PM
04/13/10 11:20 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
It sounds like a faulty connection to me. The best way to test is not using the ohm meter function of the DVOM. Using the ohm meter will not tell you if the circuit fails under higher amperage load. Use the voltmeter. Start with one lead attached to the positive battery post. Use the other lead to probe the positive circuit from the battery through the fire wall bulkhead,then the ignition switch,though the bulkhead again to the ballast resistor then the coil. Since you are probing positive to positive you should get a zero volt reading. Any reading on the meter shows how much was lost at that individual connection. Test the entire ignition feed circuit and I bet you find a individual or multiple connections with high voltage drop. Repair them as needed. Good luck. Doug
I was suggesting to check the ballast resistor with the Ohm aspect of the meter.
