Mannn i hate my carrr! jk #667819
04/12/10 03:04 AM
04/12/10 03:04 AM
Detroit,Michigan USA!
E
erick72 Offline OP
erick72  Offline OP
E
well i been meesing with my electrical gremlin lately and ive gotten power to my ballast. in the mid elevens for power.but my coil has only 2.8 what would cause this?
Re: Mannn i hate my carrr! jk [Re: erick72] #667820
04/12/10 08:49 AM
04/12/10 08:49 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If you have 11's coming out of the ballast it should still be 11's when it gets to the coil. I would assume the wire ( ballast to coil) is broken and or cooked. It is 37 years old
run a test wire straight from the ballast to the + on the coil minimum 12
Re: Mannn i hate my carrr! jk [Re: Dodgem] #667821
04/13/10 02:48 AM
04/13/10 02:48 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
He said he's got 11s to the ballast resistor, not coming out of it. Voltage coming out of resistor should be lower since it is after all going through a resistor.
Check out this thread
https://board.moparts.org/ubbthreads/show...rue#Post5237155
Re: Mannn i hate my carrr! jk [Re: erick72] #667822
04/13/10 10:14 AM
04/13/10 10:14 AM
mid 11 volts to the Ballast/2.8 @coil as said if the wire/connections from the ballast "out" downstream to the coil positive are good then the ballast is bad/dropping the voltage too much but I've got a feeling that isn't the case
Re: Mannn i hate my carrr! jk [Re: RapidRobert] #667823
04/13/10 12:05 PM
04/13/10 12:05 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Could you please clarify in English?
Re: Mannn i hate my carrr! jk [Re: rss] #667824
04/13/10 12:27 PM
04/13/10 12:27 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Mid 11 volts to the Ballast/2.8 at the coil.
As said, if the wire/connections from the ballast "out" downstream to the coil positive are good, then the ballast is bad/dropping the voltage too much.
I've got a feeling that isn't the case.
Re: Mannn i hate my carrr! jk [Re: Pat_Whalen] #667825
04/13/10 12:34 PM
04/13/10 12:34 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
If you've got a DVOM (digital volt ohm meter), you can pull both connections from the ballast resistor and meter it for resistance. Let us know what you've got. 11v at the front of the ballast, but what is your actual battery voltage? They should be the same. If not, you're dropping voltage somewhere. Points or electronic?
Re: Mannn i hate my carrr! jk [Re: Pat_Whalen] #667826
04/13/10 01:29 PM
04/13/10 01:29 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
It may not be related to your problem at all, but when I first put mine back together I had to re-do some wiring under the hood because someone just cut the harness when they sold the original motor out of it. It would fire up, then barely run at all above an idle- Eventually figured out all it was I had the wiring hooked up wrong to the resistor...had them switched
Re: Mannn i hate my carrr! jk [Re: donbarnes] #667827
04/13/10 05:57 PM
04/13/10 05:57 PM
Eric w your voltmeter w it at a fast idle put the neg lead on the batt neg post and start checking voltages at every point starting at the battery positive post then to the starter relay then stick a thin probe into the bulkhead terminal & check it's voltage then on the other side of the bulkhead "out" to the ballast, check both sides then see what you have at the coil positive and if it's 2.8V it would not be firing.
Re: Mannn i hate my carrr! jk [Re: rss] #667828
04/13/10 06:10 PM
04/13/10 06:10 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Brain fart but 9 volts out after it is resisted down. But on start ballast is by passed to 12V so it should start then quit??
Re: Mannn i hate my carrr! jk [Re: Dodgem] #667829
04/13/10 06:13 PM
04/13/10 06:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
diagram
Re: Mannn i hate my carrr! jk [Re: Dodgem] #667830
04/13/10 08:21 PM
04/13/10 08:21 PM
and I cant see it being 2.8V on the run side so that makes me think something is being missed
Re: Mannn i hate my carrr! jk [Re: RapidRobert] #667831
04/13/10 10:05 PM
04/13/10 10:05 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It sounds like a faulty connection to me. The best way to test is not using the ohm meter function of the DVOM. Using the ohm meter will not tell you if the circuit fails under higher amperage load. Use the voltmeter. Start with one lead attached to the positive battery post. Use the other lead to probe the positive circuit from the battery through the fire wall bulkhead,then the ignition switch,though the bulkhead again to the ballast resistor then the coil. Since you are probing positive to positive you should get a zero volt reading. Any reading on the meter shows how much was lost at that individual connection. Test the entire ignition feed circuit and I bet you find a individual or multiple connections with high voltage drop. Repair them as needed. Good luck.
Doug
Re: Mannn i hate my carrr! jk [Re: dvw] #667832
04/13/10 11:20 PM
04/13/10 11:20 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Doug
I was suggesting to check the ballast resistor with the Ohm aspect of the meter.
Re: Mannn i hate my carrr! jk [Re: Pat_Whalen] #667833
04/24/10 12:14 AM
04/24/10 12:14 AM
E
erick72 Offline OP
erick72  Offline OP
E
sorry for the long reply. i kinda put my car to the side its been making me so mad. and im just trying to get school done. but now i fifnished what i needed to do.
so back to the point i think i may try to run a wire from the ballast straight to the coil.
