small block converter choice #667571
04/11/10 10:30 PM
04/11/10 10:30 PM
mo
ALKYW5DART Offline OP
mo
i have a 416 small block w5 heads flow 329/252 430 gears, 28" tire, 1050 alky dominator 703/683 cam car weighs 3000 with me. i want a 5500 stall engine builder says 4400 whats your guys take on it thanks
Re: small block converter choice [Re: ALKYW5DART] #667572
04/11/10 10:35 PM
04/11/10 10:35 PM
PA
moparacer Offline
moparacer  Offline
PA
I think your right....
4400 is too low.
Will hurt 60ft.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: small block converter choice [Re: ALKYW5DART] #667573
04/11/10 10:39 PM
04/11/10 10:39 PM
oregon
greendart408 Offline
oregon
I have a fairly similar combo to you and I have a 5500. Mine works well.
Re: small block converter choice [Re: ALKYW5DART] #667574
04/12/10 12:01 AM
04/12/10 12:01 AM
mo
mo
how close is your combo is it a 4" stroke or 3.79
Re: small block converter choice [Re: ALKYW5DART] #667575
04/12/10 12:10 AM
04/12/10 12:10 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
we ran a used 9" Coan that Lenny at Ultimate worked over. Believe it stalled around 5000. We've never gotten the car to 60 worth a hoot. Shock changes, spring changes, ladder bar changes. This spring we're installing an 8" that should stall in the 5500-5600 range. Hopefully that will bring my dads Duster alive. I think the car grabbed a couple high 1.4's, but most of the time it was in the low 1.5's. I'm thinking that high/mid 1.3's should be the norm. We'll see.....
Re: small block converter choice [Re: ALKYW5DART] #667576
04/12/10 12:32 AM
04/12/10 12:32 AM
oregon
oregon
Mine is 4"
Re: small block converter choice [Re: greendart408] #667577
04/12/10 10:40 AM
04/12/10 10:40 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
5500 if you can keep it efficient. 5-7% slippage
Re: small block converter choice [Re: DavidDean] #667578
04/12/10 11:13 AM
04/12/10 11:13 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
My old w5 motor worked best at 5200-5300 flash.Buy 5500 isnt going to be off much if any, you didnt mention cam duration or compression either.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: small block converter choice [Re: B3422W5] #667579
04/12/10 02:37 PM
04/12/10 02:37 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
I think every engine will be different, ours runs about the same 4500-5500
Re: small block converter choice [Re: Dustedu] #667580
04/12/10 07:01 PM
04/12/10 07:01 PM
mo
mo
compresion is a true 13.5 to 1 cam is 711 694 275/282@50
