Re: best place to get holley carb rebuild
[Re: Bossman963]
#666838
04/11/10 01:28 PM
04/11/10 01:28 PM
Posts: 576 Bend, Oregon
67cuda340
super street
super street
Bend, Oregon
I would take off the bowls and see if it is worth rebuilding. If there is pitting inside it may not be worth it. Holleys are not diffucult by a book and a quality kit and give it a try.
1973 Dodge Dart Sport 360 Drag radials
12.30 1/4 mile 7.82 1/8 mile
[Re: barryv]
#666840
04/11/10 05:08 PM
04/11/10 05:08 PM
RapidRobert
Check the float levels & open it up again and see what come undone/loose as you had it good & something changed and you can find what that is yourself which will save you time/money and build your confidence for the next obatacle on down the line. More details on what happened
[Re: 67cuda340]
#666842
04/11/10 09:40 PM
04/11/10 09:40 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Thank you for your business and the props rm23j8g, I appreciate it As far as who the "best" is, that all depends on your needs. As mentioned by others, a (BASIC) rebuild of a Holley is not a difficult DIY project, but many of them require more than that, especially if they are really nasty old cores with a rare part# or date codes you are trying to salvage (see pic posted of one I recently took on). If your carb is beyond a home rebuild job, or you just don't want to spend the time and effort to attempt one, for the average "driver" rebuild job there are carburetor shops in nearly every city in the country that can likely perform an adequate job for you. If you want something detailed to the "nth degree" in show quality OEM details your choices will narrow, it just depends on what you are after. Feel free to contact me if you need further help.
