Switch to Manual Brakes. #666611
04/11/10 12:26 AM
04/11/10 12:26 AM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
73 Duster, front discs, Has power currently, the stroker will be pulling just under what it'd take to run a booster, plus, a car this light with good discs I don't think it's really needed.
I plan on getting a new Master cylinder anyways, what all do I need to swap exactly? I know I will need a manual brake push rod and the bushing...Isn't that all?
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Switch to Manual Brakes. [Re: MonGoo$e] #666612
04/11/10 12:38 AM
04/11/10 12:38 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
that is all i did on my 73 duster..
replaced master cylinder with newer mopar with adapter for two bolts..
bought manual pushrod...slowly bent brake lines to line up with new master cylinder.
Tony
70 AARCuda Vitamin C
Re: Switch to Manual Brakes. [Re: 70AARcuda] #666613
04/11/10 12:45 AM
04/11/10 12:45 AM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
good deal, thanks for the input
Re: Switch to Manual Brakes. [Re: 70AARcuda] #666614
04/11/10 09:48 AM
04/11/10 09:48 AM
What 70AARcuda said just a M/C with the recess for the neoprene retainer and the MB pushrod. Best would be to get an alum M/C of the CORRECT bore size w the 4 bolt to 2 bolt alum adapter plate and I thought all manual pushrods were the same length but I happened to see 2 side by side and they are different and I dont know what they come out of so the MP adjustable pushrod MAY be needed to get your pedal where you want it.
