65 Coronet #66644
05/31/08 01:44 PM
05/31/08 01:44 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
I bought a set of inner fender shield seals for the Coronet. Can anybody tell me how to install them? The seals are in four pieces, with 8 clips & 8 staples. The fender shields don't seem to have holes to fasten the seals to. Need help. Thanks alot.
Re: 65 Coronet [Re: vjb] #66645
06/03/08 03:00 AM
06/03/08 03:00 AM
Sooner state
Slim Smitty Offline
Slim Smitty  Offline
Sooner state
I put all that stuff on my 65 last summer. Are you talking about the inner rear splash shield (tall, vertical shield mounted behind wheel) or the inner front splash shield (by the headlights)?
I remember the inner front splash shield seals popping into the shield through holes. But I can't recall exactly how the rear splash shield seals went on. I want to say that they slide over the edge of the shield. I'll have a look at them and see if I can remember exactly.
- - - - - - - 65 Coronet
Re: 65 Coronet [Re: Slim Smitty] #66646
06/04/08 04:02 PM
06/04/08 04:02 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
These are the rear inner splash shield seals. What I have does not look like what I need. Any help will be greatly appreciated.
Re: 65 Coronet [Re: vjb] #66647
06/06/08 01:12 PM
06/06/08 01:12 PM
Sooner state
Slim Smitty Offline
Slim Smitty  Offline
Sooner state
Here are some pics of my inner rear splash shields. They definitely pop into existing holes. There's one long seal that goes from top to bottom and one top seal. Both seals pop into existing holes in the splash shields.
Here's the original tall vertical seal snapped in place from the back side of the seal as removed from my car:
Re: 65 Coronet [Re: Slim Smitty] #66648
06/06/08 01:15 PM
06/06/08 01:15 PM
Sooner state
Slim Smitty Offline
Slim Smitty  Offline
Sooner state
Close up of vertical seal
Re: 65 Coronet [Re: Slim Smitty] #66649
06/06/08 01:16 PM
06/06/08 01:16 PM
Sooner state
Slim Smitty Offline
Slim Smitty  Offline
Sooner state
View of vertical seal from front side of splash shield
Re: 65 Coronet [Re: Slim Smitty] #66650
06/06/08 01:17 PM
06/06/08 01:17 PM
Sooner state
Slim Smitty Offline
Slim Smitty  Offline
Sooner state
Upper splash shield seal for the inner fender rear splash shield
Re: 65 Coronet [Re: Slim Smitty] #66651
06/06/08 01:20 PM
06/06/08 01:20 PM
Sooner state
Slim Smitty Offline
Slim Smitty  Offline
Sooner state
Here's the inner splash shields that I freshened up before installing the new seals. You cann see the holes in the splash shields for the clips.
You can also see the holes for the top splash shield in the shield on the right in this pic. It has staggered holes that match the staggered shape of that top seal.
Hope this helps!
Re: 65 Coronet [Re: Slim Smitty] #66652
06/06/08 02:42 PM
06/06/08 02:42 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
Thanks for the pics. What Restoration Specialties called a splash shield seal is definitely not what you showed me. Where did you get the seals from? Where did you get the splash shields from? Mine came from Laysons and did not have the small clip holes. Thanks for the help.
Re: 65 Coronet [Re: vjb] #66653
06/06/08 03:21 PM
06/06/08 03:21 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
Just got off the phone w/ Restoration Spec. Turns out I ordered Frame Rail Seals. My fault. No wonder I couldn't fit them! Still, where did you get the shields from? I like yours better.
Re: 65 Coronet [Re: vjb] #66654
06/06/08 03:28 PM
06/06/08 03:28 PM
Sooner state
Slim Smitty Offline
Slim Smitty  Offline
Sooner state
Splash shields are original to the car, I refurbished them myself. Splash shield seals were bought on ebay a couple of years ago. They came in some funky 70s packaging, so they were old.
I would refer you to Joe Suchy for the seals. He sells all the early B stuff. And he knows the early b's like no one else. You won't go wrong with him. I met him a few years ago. Great guy.
His email:
dinahandjoe@peoplepc.com
He's also got a complete list of all the new stuff he sells listed on the 62-65 mopar site. And he has tons of original parts. If you need the actual splash shields, I'm sure he has them.
Get in touch with him and you won't have to do any guess work.
Layson's repopped sheetmetal is disapponting. I bought one piece from them and it was useless.
Re: 65 Coronet [Re: Slim Smitty] #66655
06/06/08 03:30 PM
06/06/08 03:30 PM
Sooner state
Slim Smitty Offline
Slim Smitty  Offline
Sooner state
I'm pretty sure Restoration Specialties and what Joe sells are the same items. It's just nice to talk to someone who knows exactly what you need. I've learned a lot from him. And when it comes to early b-bodies, there aren't nearly as many informed suppliers as the 66 and up suppliers.
