New carbs installed. #666399
04/10/10 08:44 PM
04/10/10 08:44 PM
PA
70HemiGTX Offline OP
PA
I installed the new carbs I had built this winter. Had to grind a clearance grove in the front of the intake for the acc. pump lever. Too much aluminum cast there. Can't wait to get it fired.
Re: New carbs installed. [Re: 70HemiGTX] #666400
04/10/10 09:35 PM
04/10/10 09:35 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
those sure look purdy. what air scoop will you use?any filter?
Re: New carbs installed. [Re: blownzoom440] #666401
04/10/10 10:45 PM
04/10/10 10:45 PM
PA
PA
I made a "custom" aircleaner for my other carbs that I will rework to fit this set. It uses a K&N 3" tall 6-pack filter and will sit down over the carbs a little.
Re: New carbs installed. [Re: 70HemiGTX] #666402
04/10/10 11:11 PM
04/10/10 11:11 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
More Pics!!!!
What tunnel ram did you use?
Re: New carbs installed. [Re: roadhazard] #666403
04/10/10 11:43 PM
04/10/10 11:43 PM
PA
PA
It's an old Weiand.
Re: New carbs installed. [Re: 70HemiGTX] #666404
04/10/10 11:50 PM
04/10/10 11:50 PM
Any thought of putting carb spacers on instead of grinding?
Re: New carbs installed. [Re: ] #666405
04/11/10 12:12 AM
04/11/10 12:12 AM
PA
PA
I only ground a spot about 3/4" long by about 3/16" wide and about 3/16" deep. Spacers are out. No room under the scoop for them also.
Re: New carbs installed. [Re: 70HemiGTX] #666406
04/11/10 01:13 AM
04/11/10 01:13 AM
Redding,CA USA
440charger500 Offline
Redding,CA USA
Are those dillman carbs? I'm getting ready to mount the same intake on my car tomorrow, looks awesome hope it hauls a$$.
Re: New carbs installed. [Re: 440charger500] #666407
04/11/10 01:16 AM
04/11/10 01:16 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
That is a thing of beauty! What is the rest of the combo?
Re: New carbs installed. [Re: 70HemiGTX] #666408
04/11/10 01:26 AM
04/11/10 01:26 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
It's an old Weiand.
nuthin wrong with an ol weiand
Re: New carbs installed. [Re: SG duster] #666409
04/11/10 08:50 AM
04/11/10 08:50 AM
PA
PA
Yes they are Dillman carbs. The rest of the combo is a 440, 516 heads (that are hogged out), 12.5 pistons, roller cam (I don't remember all the specs off the top of my head.) And a 4 speed.
Re: New carbs installed. [Re: 70HemiGTX] #666410
04/11/10 09:03 AM
04/11/10 09:03 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I like
Have the same intake with a pair of 750 DP's and Pro Form main bodies on the shelf waiting
From what I understand the set up is worth .2-.3 in ET over a single plane set up.
Re: New carbs installed. [Re: roadhazard] #666411
04/11/10 09:30 AM
04/11/10 09:30 AM
PA
PA
I should have given the carb info also. They are 660 center squirters that have been all reworked. They flow around 695 now and have metering blocks in the rear. Really nice carbs! Atleast to look at. We will find out when I fire them up.
Re: New carbs installed. [Re: SG duster] #666412
04/11/10 10:04 AM
04/11/10 10:04 AM
It's an old Weiand.
I agree 100% with that statement.
