Will 10 gauge wire work for battery to bulk head and... #666382
04/10/10 08:26 PM
04/10/10 08:26 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I am building my own battery cables for my 70 Charger RT and I was wanting to know if 10 gauge wire would work for the small red wire that goes from the battery to the starter relay on the firewall.
And if 10 gauge wire would also work for the grey wire that goes from the starter relay to the starter???
Re: Will 10 gauge wire work for battery to bulk head and... [Re: Blakcharger440] #666383
04/10/10 09:15 PM
04/10/10 09:15 PM
my 65 Imperial wiring diagram shows a 12ga from the relay into the bulkhead protected by a 16 ga FL so 10ga would ge a step up. Which other (grey) wire are you asking about?
Re: Will 10 gauge wire work for battery to bulk head and... [Re: RapidRobert] #666384
04/10/10 09:37 PM
04/10/10 09:37 PM
Port Hope, Ontario
TheMoparJunky Offline
mopar addict
mopar addict
Port Hope, Ontario
10 gauge would work. Either I'm guessing it's goin' to your ignition switch or your fuse box. If the grey one is going to your starter it's gotta be the starter wire to the solenoid, which should be no different than a field wire to your alt. Aslong as it feeds 12 volts and excites it (engages the solenoid/washer).Make sure there is no diode in the system your replacing(sorry worked on boats, motorcycles and airplanes the last 2 years and have forgotten the systems). But should be pretty straight forward.
The Mopar Junky
Back off the Mopar bandwagon- Wannabe Millwright Enjoying the fat lazy unemployed life
Re: Will 10 gauge wire work for battery to bulk head and... [Re: Blakcharger440] #666385
04/10/10 10:13 PM
04/10/10 10:13 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
If going into the bulkhead connector, most likely is for the amp guage. Use 10 guage..
Just my $0.01...
Re: Will 10 gauge wire work for battery to bulk head and... [Re: Sinitro] #666386
04/10/10 11:32 PM
04/10/10 11:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do you still have a fusible link?
Re: Will 10 gauge wire work for battery to bulk head and... [Re: Sinitro] #666387
04/10/10 11:35 PM
04/10/10 11:35 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
is more important a good alt, then the 10 gauge wire into alt wire, more than the batt wire itself where 12 could be enough... some other procedures are also advised depending on alternator used and equipment options
Re: Will 10 gauge wire work for battery to bulk head and... [Re: NachoRT74] #666388
04/11/10 09:02 AM
04/11/10 09:02 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
If you are rewiring the car. Why don't you just run the heavy wire from the alternator to the starter relay (which is actually the connection to the battery.
What is this grey wire from bulkhead to the starter?
The only wires to the starter should be a constant power which is the big positive battery wire and a small brown wire from the starter relay.
Re: Will 10 gauge wire work for battery to bulk head and... [Re: Magnum] #666389
04/11/10 10:13 AM
04/11/10 10:13 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
and the yellow one coming from ignition and the blue ( if stock ) fuse link.
The car power demand is still inside the car so thats the point to get the power hook. Unless you run the wire directly to starter relay stud and you are still keeping the stock wire from alt to inside the cab, get JUST the wire from alt to starter realy stud will burn bulkhead by sure.
Only way to make work that extra wire safelly is if you run it as an extra one, but will be "bypassing" the ammeter ( is not really bypass, is really a missread on the system, like no charge/discharge due the big load going on the easier way thorugh both wires )
Re: Will 10 gauge wire work for battery to bulk head and... [Re: Magnum] #666390
04/11/10 10:30 AM
04/11/10 10:30 AM
Wichita,KS
Wichita,KS
I made a mistake. I went and made corrections in my first post so you know what I am talking about.
The wires I am referring to are the small red wire that goes from the positive battery post to the starter relay on the firewall and the grey wire from the starter relay to the starter itself.
I notice that the stock wires that route to the starter relay have hard black rubber blocks near the connector ends...what purpose do these rubber blocks serve? I will try to post a pic of them.
Re: Will 10 gauge wire work for battery to bulk head and... [Re: stumpy] #666391
04/11/10 10:31 AM
04/11/10 10:31 AM
Wichita,KS
Wichita,KS
I still have the factory fusible link.
Re: Will 10 gauge wire work for battery to bulk head and... [Re: Blakcharger440] #666392
04/11/10 10:49 AM
04/11/10 10:49 AM
Wichita,KS
Wichita,KS
What are the black rubber blocks for near the end of the wire connectors which go to the starter relay?
Re: Will 10 gauge wire work for battery to bulk head and... [Re: Blakcharger440] #666393
04/11/10 11:06 AM
04/11/10 11:06 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
simply terminal isolation...
oh ok thats the grey wire... I think normally is black... maybe faded ?
Re: Will 10 gauge wire work for battery to bulk head and... [Re: Blakcharger440] #666394
04/11/10 11:51 AM
04/11/10 11:51 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
these two wires look like the ones going to the starter relay.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Will 10 gauge wire work for battery to bulk head and... [Re: HealthServices] #666395
04/11/10 11:54 AM
04/11/10 11:54 AM
So Cal
So Cal
here too
Re: Will 10 gauge wire work for battery to bulk head and... [Re: HealthServices] #666396
04/11/10 12:18 PM
04/11/10 12:18 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yes those are... rubber blocks are simply terminal/wire splice insulation
