Re: neon revs up by its self! throttle sensor?
[Re: dirt]
#666291
04/10/10 07:29 PM
04/10/10 07:29 PM
Posts: 12,292 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Check the connecting bellows between the intake manifold and the air box. The throttle body is mounted on the air box and if the bellows has a leak then the RPMs take off uncontrollably.
Master, again and still
[Re: dirt]
#666292
04/10/10 07:54 PM
04/10/10 07:54 PM
Posts: 12,245 Looking for a way out of Middl...
IMGTX
Check the Tube going from the EGR Valve to the intake manifold. They will come loose and the engine will take off. As far as the electronics can tell the engine is getting air so it feeds it more fuel and apparently ignores the TPS. It's under the Throttle Body next to the battery area. Hope it helps. ![](/ubbthreads/images/graemlins/thumbs.gif)
