neon revs up by its self! throttle sensor? #666290
04/10/10 07:11 PM
04/10/10 07:11 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
2004 neon . it just started reving up with out me giving it any throttle. i turned it off before it got too far and tried again but it will go past 4000 rpm by its self.
could it be the throttle position sensor or something else?
i had an 86 daytona do that one time and it was the sensor.
any ideas? thanks
Re: neon revs up by its self! throttle sensor? [Re: dirt] #666291
04/10/10 07:29 PM
04/10/10 07:29 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Check the connecting bellows between the intake manifold and the air box. The throttle body is mounted on the air box and if the bellows has a leak then the RPMs take off uncontrollably.
Master, again and still
Re: neon revs up by its self! throttle sensor? [Re: dirt] #666292
04/10/10 07:54 PM
04/10/10 07:54 PM
IMGTX Offline
IMGTX  Offline
Check the Tube going from the EGR Valve to the intake manifold. They will come loose and the engine will take off. As far as the electronics can tell the engine is getting air so it feeds it more fuel and apparently ignores the TPS.
It's under the Throttle Body next to the battery area.
Hope it helps.
Re: neon revs up by its self! throttle sensor? [Re: DaveRS23] #666293
04/10/10 09:53 PM
04/10/10 09:53 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
The bellows seal with a big hose clamp on each end. Check the clamps for tightness, and the bellows itself for cracks or holes.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
