HELP MANUAL MASTER CYL. SET UP DAIGRAM #666159
04/10/10 04:11 PM
04/10/10 04:11 PM
Dennispsalm91 Offline OP
Looking to put the master cylinder together on my challenger. Need to know the order of putting back together. Car came without master cylinder hooked up. I have the maual master cylinder, the steel plate, a gasket , plastic like gasket with a rubber sleeve and aluminum plate. My 73 sevice manual doesnt show the set up - go figure, any help would be appreciated
Re: HELP MANUAL MASTER CYL. SET UP DAIGRAM [Re: Dennispsalm91] #666160
04/11/10 03:18 PM
04/11/10 03:18 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Can you post a pic of the parts? We can probably help with the correct order then.
Re: HELP MANUAL MASTER CYL. SET UP DAIGRAM [Re: Dennispsalm91] #666161
04/11/10 03:46 PM
04/11/10 03:46 PM
I'm pretty sure the reinforcing plate goes on the front side of the firewall and the thin flat plastic squarish piece w the boot for sure goes right on the back side of the M/C
Re: HELP MANUAL MASTER CYL. SET UP DAIGRAM [Re: Dennispsalm91] #666162
04/11/10 06:21 PM
04/11/10 06:21 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
From the 73 Factory Parts Book
Re: HELP MANUAL MASTER CYL. SET UP DAIGRAM [Re: Snoopy] #666163
04/11/10 06:21 PM
04/11/10 06:21 PM
Snoopy Offline
Snoopy  Offline
2
Re: HELP MANUAL MASTER CYL. SET UP DAIGRAM [Re: Snoopy] #666164
04/11/10 11:17 PM
04/11/10 11:17 PM
Thanks guys
Re: HELP MANUAL MASTER CYL. SET UP DAIGRAM [Re: Dennispsalm91] #666165
04/12/10 01:33 PM
04/12/10 01:33 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
also,when manual brakes,at least on -70 cuda(i think) there should be harness hangers/hooks on the upper bolts/studs of the reinforcement plate,am i right folks??i do not know what that mounting hardware looks like,but i hope someone with a camera chimes in,overandout
