what throttle cable and mount?? #665647
04/09/10 08:54 PM
04/09/10 08:54 PM
nc
E
earthmover Offline OP
E
nc
what cable and mount do most of you guys run???i have the factory 2barr cable with a modi. bracket that i made from the factory 1.. its about 1.5" taller and moved to the front a little...works pretty good but thinking of getting something new...thought about the lokar 1,and thought about the 1s that are made out of alum. tube with the heims ends on it..brother in law had 1 on his car worked really good...set up is alum intake with 1"open spacer...
Re: what throttle cable and mount?? [Re: earthmover] #665648
04/09/10 09:04 PM
04/09/10 09:04 PM
AndyF Offline
AndyF  Offline
Mancini Racing sells a bunch of different throttle cables and brackets.
Re: what throttle cable and mount?? [Re: AndyF] #665649
04/09/10 09:14 PM
04/09/10 09:14 PM
nothing better than the stock throttle cable.
leave it alone imo.
Re: what throttle cable and mount?? #665650
04/09/10 09:20 PM
04/09/10 09:20 PM
NC
barracuda man Offline
NC
Re: what throttle cable and mount?? [Re: barracuda man] #665651
04/10/10 12:18 AM
04/10/10 12:18 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
X2
I use an AndyF bracket with a stock throttle cable.
Re: what throttle cable and mount?? [Re: G_bob] #665652
04/10/10 02:04 AM
04/10/10 02:04 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
x3 AndyF bracket stock cable
Re: what throttle cable and mount?? [Re: Joshs68] #665653
04/10/10 06:18 AM
04/10/10 06:18 AM
Q
Quicktree Offline
Quicktree  Offline
Q
jegs has the best loooking mount and you can use a stock cable. look them up. they mount on the base plate of the carb out of the way.
Re: what throttle cable and mount?? [Re: Quicktree] #665654
04/10/10 07:31 AM
04/10/10 07:31 AM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
And they have an intergrated return spring mount.
Steve
Photobucket sucks
Re: what throttle cable and mount?? [Re: 72chrgrally] #665655
04/10/10 10:59 AM
04/10/10 10:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use Mancinis bracket and a modified /6 cable on my 440 M1 and Dominator carb.Works perfect.If I didnt have a 65 pedal I would not have to have moded the cable at the pedal.Rocky
Chrysler Firepower
Re: what throttle cable and mount?? [Re: Quicktree] #665656
04/10/10 01:22 PM
04/10/10 01:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s what I`m running and w/the 2" adapter it keeps things level w/the carb and not pointing up like others.
Re: what throttle cable and mount?? [Re: G_bob] #665657
04/10/10 01:28 PM
04/10/10 01:28 PM
X2
i use AndyF crossram indy bracket. works great. his attention to detail is excellant.
Re: what throttle cable and mount?? [Re: G_bob] #665658
04/10/10 08:15 PM
04/10/10 08:15 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
X2
What do you have bolted on the carb? Does the throttle cable attach directly to the carb or is there another bracke in there?
1974 Roadrunner
1967 Charger
Re: what throttle cable and mount?? [Re: Saskabusa] #665659
04/10/10 09:31 PM
04/10/10 09:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
heres a pic of the jegs. maybe hard to see because it's black. this is by far the best bracket out there.
Re: what throttle cable and mount?? [Re: Quicktree] #665660
04/10/10 09:52 PM
04/10/10 09:52 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
stock 6 cy cable and home made bracket..them lokar cable are ok for street rods.. but not good for race cars !
Re: what throttle cable and mount?? [Re: VernMotor] #665661
04/10/10 09:55 PM
04/10/10 09:55 PM
tboomer Offline
tboomer  Offline
Andy F mount...None finer!!
Re: what throttle cable and mount?? [Re: tboomer] #665662
04/10/10 11:18 PM
04/10/10 11:18 PM
nc
E
E
nc
hay thats what my bracket looks like vern i geuss theres no need to buy if what you have works...thanks for all the help guys
