Re: Main Girdle... [Re: smokinwoody] #665606
04/11/10 10:26 AM
04/11/10 10:26 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I have one in mine...if you are racing a stock block like we are, it wont matter what HP level you are at...its a good thing to have...
x 1000000 also. i used the chenowith in my old setup
Mopar Performance
Re: Main Girdle... [Re: moparniac] #665607
04/11/10 05:23 PM
04/11/10 05:23 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
Chenowith here to, my engine guy was impressed and he's a chevy guy!
Re: Main Girdle... [Re: Thor500] #665608
04/11/10 10:01 PM
04/11/10 10:01 PM
Long Island, NY.
Stroked65Belv Offline
Long Island, NY.
I am considering one as well in my 440/498 stroker. Engine is in the car and I didnt build it so not sure what is down there. Need to replace the pan so I have read that some need machine work to the block for proper fitment. Is there a reasonably priced unit that can be direct bolt in without removing the engine and needing machine work? (as in what I have read in tech articles about the block needing to be line honed for studs) Whats the story? anyone know difference regarding a kit so this can be avoided?
Re: Main Girdle... [Re: Stroked65Belv] #665609
04/13/10 05:46 PM
04/13/10 05:46 PM
tboomer Online work OP
tboomer  Online Work OP
I think Hughes has a kit that bolts in from the bottom?? I have been checking prices...They are all over the place!! Are they all not the same??
Re: Main Girdle... [Re: tboomer] #665610
04/13/10 07:47 PM
04/13/10 07:47 PM
Long Island, NY.
Long Island, NY.
Just dropped my pan. Luckily my block was outfitted with studs so I am hoping all goes well with the 1/4" girdle kit from 440 source. Most of the research I have done the 1/4" kits appear the same. I found mine for $275 . Everyone else's was $$$ Up much more once you went to 1/2". That was a trick looking piece but didnt think I needed it for my application.
Re: Main Girdle... [Re: Stroked65Belv] #665611
10/31/10 10:43 PM
10/31/10 10:43 PM
Missouri
Challenger Offline
Challenger  Offline
Missouri
Does anyone know how thick the Hughes main girdle is?
Re: Main Girdle... [Re: Challenger] #665612
11/01/10 12:06 PM
11/01/10 12:06 PM
ky
68roadrunner Offline
ky
3/8 thick
Re: Main Girdle... [Re: 68roadrunner] #665613
11/01/10 01:38 PM
11/01/10 01:38 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
It is less than 1/4"
Re: Main Girdle... [Re: moparlifer] #665614
11/01/10 01:47 PM
11/01/10 01:47 PM
BCR girdle on mine - 1/2" thick
Re: Main Girdle... [Re: ] #665615
11/01/10 09:46 PM
11/01/10 09:46 PM
Missouri
Challenger Offline
Challenger  Offline
Missouri
So one of you tells me 3/8ths and another tells me less than a 1/4. Anyone else, I dont seem to have a definitive answer. Guess Ill just email them and see whats up!
Re: Main Girdle... [Re: Challenger] #665616
11/02/10 02:04 PM
11/02/10 02:04 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'm sure my hughes is 1/4 it may be 5/16 but it's not 3/8 like a chet. I'm pretty sure it's 1/4 car is not hear so???
Re: Main Girdle... [Re: Dodgem] #665617
11/02/10 06:00 PM
11/02/10 06:00 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
CRE on my 446 ci been on three years it's 1/4" and I shift it at 6800
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
