Harley Davidson SAE 40 oil Ok to use in car? #665489
04/09/10 06:46 PM
04/09/10 06:46 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Is this oil ok to use in an old car or truck engine?
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: rapom] #665490
04/09/10 07:13 PM
04/09/10 07:13 PM
IN
ahy Offline
ahy  Offline
IN
Motorcycle oils are good quality and have ample zinc. I'd be concerned about straight 40 though. At start up oil pressure could shoot too high plus power and economy would suffer with the heavy oil.
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: ahy] #665491
04/09/10 09:48 PM
04/09/10 09:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
40 weight won't build up that high a pressure that it would cause any problems. I've used 40 weight in a bunch of old worn out motors and had no trouble. Keeps them going for a while longer.
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: stumpy] #665492
04/10/10 08:50 AM
04/10/10 08:50 AM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
What I was thinking of doing is only using it in the summer and spiking it with 1 qt. of Marvel Mystery oil which is what I do anyway with the other multi-viscosity oils.
I found some HD SAE40 oil for sale in a sealed 55 gal. drum for $1 per gal. Which I thought was a good deal. I was pretty sure it also had the extra zinc in it also.
Thanks for the feedback.
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: rapom] #665493
04/10/10 10:45 AM
04/10/10 10:45 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run 20w 50 in my HDs and in the 440.Never hurt
anything.At a buck a gallon Id buy a drum myself.Run it.It wont hurt a thing.Rocky
Chrysler Firepower
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: rapom] #665494
04/10/10 06:39 PM
04/10/10 06:39 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
I think it will leak everytime you shut it down.
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: FuryUs] #665495
04/10/10 11:03 PM
04/10/10 11:03 PM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: rapom] #665496
04/11/10 06:49 AM
04/11/10 06:49 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Back in the day, Chrysler suggested using 40 weight engine oil, especially in their performance engines
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: rapom] #665497
04/11/10 08:09 AM
04/11/10 08:09 AM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
You get what you pay for....
Do you know who make HD oil? Neither do they!
The fact is that Harley-Davidson, like so many other "brands" of oil, contract with one or more oil companies to make their lubricants. Often, the decision as to who actually makes a private labeled product is based on low bid, and like almost everything manufactured by a low bidder, short cuts are taken in order to meet the low price.
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: Spike] #665498
04/11/10 03:59 PM
04/11/10 03:59 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
I believe the drums are from a HD Dealer that went out of business.
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: therocks] #665499
04/11/10 04:06 PM
04/11/10 04:06 PM
Me too
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: rapom] #665500
04/11/10 04:07 PM
04/11/10 04:07 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
40 W will be fine, even straight. I've ran it alot, years ago.
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: Spike] #665501
04/11/10 04:10 PM
04/11/10 04:10 PM
Cincinnati, Ohio
Cincinnati, Ohio
I call BS,
That's great deal! Buy it.
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: Challenger 1] #665502
04/11/10 04:27 PM
04/11/10 04:27 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Over the years I have found that I will consistantly have better warm oil pressure with multigrades than with straight grade oils. IE better warm with 10/30 than with straight 30 weight.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Harley Davidson SAE 40 oil Ok to use in car? [Re: Challenger 1] #665503
04/11/10 06:11 PM
04/11/10 06:11 PM
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
I call BS,
You can't be serious. Harley is in the business of making bikes not oil. Do you know how much they would have to invest to produce their own oil.
They bid on it, like walmart and all the others who have their name on a oil that would never make it for themselves.
Get the facts, there is no Harley made oil.
