Reverse manual valve body question... #66453
05/30/08 11:04 PM
05/30/08 11:04 PM
New Mexico
Adobedude Offline OP
New Mexico
I just swapped out a 46RE for a CRT 727
With a reverse pattern manual valve body, when the shift lever on the transmission is all the way forward, is it in park or 1st?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Reverse manual valve body question... [Re: Adobedude] #66454
05/30/08 11:38 PM
05/30/08 11:38 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
P R N 3 2 1
park is full forward on the shifter !
Re: Reverse manual valve body question... [Re: calrobb2000] #66455
05/30/08 11:44 PM
05/30/08 11:44 PM
New Mexico
New Mexico
I thought PRN321 is the forward pattern, wouldn't the reverse pattern be PRN123 on the B&M shifter.
What about on the transmission?
If the lever is all the way forward what gear is the transmission in?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Reverse manual valve body question... [Re: Adobedude] #66456
05/30/08 11:48 PM
05/30/08 11:48 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Yes, reverse pattern in P R N D 2 3
Ride eternal, shiny and chrome
Re: Reverse manual valve body question... [Re: Adobedude] #66457
05/31/08 01:55 AM
05/31/08 01:55 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
You are correct. reverse pattern is PRN123.
I use a b and m mega shifter with my 727. It shows the regular pattern(PRN321) on the shift indicator.
Once you use it, you really don't need to be reminded where to shift it. It becomes quite obvious when you run it up to 20 mph, and it doesn't change gears
Re: Reverse manual valve body question... [Re: Adobedude] #66458
05/31/08 06:54 AM
05/31/08 06:54 AM
i picked up aftermarket shifter for my reverse pattern trans,has pistol grip,lock out gates and reverse pattern on the handle. best of both worlds!
Re: Reverse manual valve body question... [Re: dave571] #66459
05/31/08 07:25 AM
05/31/08 07:25 AM
New Mexico
New Mexico
B&M makes an reverse patttern indicator plate for the Megashifter.
But I stil need to know what gear the transmission is in when the lever on the transmission, (shifter unhooked) is in the full forward position.
On an automatic valvebody, that would be 1st gear....But does that change on a manual/reverse pattern valve body?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Reverse manual valve body question... [Re: Adobedude] #66460
05/31/08 09:37 AM
05/31/08 09:37 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
On the trans, park is to the rear. So with a reverse pattern v.b. the order is, starting with the lever forward, is 3, 2, 1, N, R, P. Hope this finally answers your question
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Reverse manual valve body question... [Re: Adobedude] #66461
05/31/08 09:37 AM
05/31/08 09:37 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yes, it is now gear 3 on reverse body. Park is the other end of travel.
Re: Reverse manual valve body question... [Re: Evil Spirit] #66462
05/31/08 09:51 AM
05/31/08 09:51 AM
New Mexico
New Mexico
That answers my question, thanks.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
