Reverse manual valve body question...
#66453
05/30/08 11:04 PM
05/30/08 11:04 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I just swapped out a 46RE for a CRT 727
With a reverse pattern manual valve body, when the shift lever on the transmission is all the way forward, is it in park or 1st?
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: Reverse manual valve body question...
[Re: Adobedude]
#66454
05/30/08 11:38 PM
05/30/08 11:38 PM
Posts: 1,979 s. e. pa.
calrobb2000
s. e. pa.
hi P R N 3 2 1 park is full forward on the shifter !
[Re: calrobb2000]
#66455
05/30/08 11:44 PM
05/30/08 11:44 PM
Adobedude
New Mexico
I thought PRN321 is the forward pattern, wouldn't the reverse pattern be PRN123 on the B&M shifter.
What about on the transmission? If the lever is all the way forward what gear is the transmission in?
[Re: Adobedude]
#66456
05/30/08 11:48 PM
05/30/08 11:48 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
Yes, reverse pattern in P R N D 2 3
Ride eternal, shiny and chrome
[Re: Adobedude]
#66457
05/31/08 01:55 AM
05/31/08 01:55 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
You are correct. reverse pattern is PRN123.
I use a b and m mega shifter with my 727. It shows the regular pattern(PRN321) on the shift indicator.
Once you use it, you really don't need to be reminded where to shift it. It becomes quite obvious when you run it up to 20 mph, and it doesn't change gears
[Re: Adobedude]
#66458
05/31/08 06:54 AM
05/31/08 06:54 AM
i picked up aftermarket shifter for my reverse pattern trans,has pistol grip,lock out gates and reverse pattern on the handle. best of both worlds!
[Re: dave571]
#66459
05/31/08 07:25 AM
05/31/08 07:25 AM
Adobedude
New Mexico
B&M makes an reverse patttern indicator plate for the Megashifter.
But I stil need to know what gear the transmission is in when the lever on the transmission, (shifter unhooked) is in the full forward position. On an automatic valvebody, that would be 1st gear....But does that change on a manual/reverse pattern valve body?
[Re: Adobedude]
#66460
05/31/08 09:37 AM
05/31/08 09:37 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
On the trans, park is to the rear. So with a reverse pattern v.b. the order is, starting with the lever forward, is 3, 2, 1, N, R, P. Hope this finally answers your question
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#66462
05/31/08 09:51 AM
05/31/08 09:51 AM
Adobedude
New Mexico
That answers my question, thanks.
