stage V hemi heads #664287
04/08/10 09:12 AM
04/08/10 09:12 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
some of you may have missed the posts on here by torkrules (john) and myself about the issues with mp aluminum hemi heads and this is what this ? is related to. if i'm going to switch to the stage v heads, which 1s do i want (for an easy conversion) and who sells them. as always thanks for your help! dave
Re: stage V hemi heads [Re: 3ddart] #664288
04/08/10 09:49 AM
04/08/10 09:49 AM
Mt. Eden Ky.
Hemi Allstate Online content
Hemi Allstate  Online Content
Mt. Eden Ky.
You want the Stage V replacement heads.
http://stores.casselent.com/Detail.bok?no=31
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Post deleted by Defbob [Re: Hemi Allstate] #664289
04/08/10 10:18 AM
04/08/10 10:18 AM
Re: stage V hemi heads #664290
04/08/10 10:29 AM
04/08/10 10:29 AM
Mt. Eden Ky.
Mt. Eden Ky.
I would also check here for members that sell them all done. the above link will have box stock only. a decent clean up is going to be needed
I only used the link because of the description and the picture. I don't know what members here sell Stage V heads. I have bought from Rick Cassel though and he is easy to deal with,and took care of a small problem for me without hesitation.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: stage V hemi heads [Re: Hemi Allstate] #664291
04/08/10 11:47 AM
04/08/10 11:47 AM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
I would highly recommend Rick Cassel though to purchase from if you have someone to do the necessary assembly/clean up work. Purchased several things from him myself.
Re: stage V hemi heads [Re: BryanRad] #664292
04/08/10 12:15 PM
04/08/10 12:15 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
For the higher hp applications, I recomend the ones that have the exhaust valve rotated 2* for the larger valves and higher flow. I didn't see a part number for that one under the link, but maybe the stock replacement ones flow enough for your needs.
And yes, buy them from an engine builder. It will save you some headaches later.
Re: stage V hemi heads [Re: 3ddart] #664293
04/08/10 12:49 PM
04/08/10 12:49 PM
P
PasiR Offline
PasiR  Offline
P
Contact Tim Banning at FHO.
Re: stage V hemi heads [Re: Dragula] #664294
04/08/10 12:50 PM
04/08/10 12:50 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
I dont understand the necessity to buy them from an engine builder, if you buy them from Rick and send them to Jeff @ Modern or take your pick of the other good head guys, what the heck matters where you buy them.
Re: stage V hemi heads [Re: 3ddart] #664295
04/08/10 12:51 PM
04/08/10 12:51 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Dave,
If you want direct bolt ons you want the replacement heads. The Millennium heads are a little more exotic and for larger displacement engines. They also move the exhaust ports up which might cause fit problems in the car(you would need custom headers).
If you want to go this route, Tim Banning at FHO is a very good source. He buys the heads raw and builds around them. I bought a set from him. They are a bit overkill for my use (He had them already built, just had to swap my valve springs. CNC ported and 2.30 intake valves) I had to do some strategic grinding around the top of cylinder to make sure those bigger valves cleared (I have a 4.255 bore. I wouldn't have to do this with a larger bore or the standard 2.25 valve).
FWIW, the Edelbrock heads appear to be a good alternative. I haven't heard anything bad about them.
Re: stage V hemi heads [Re: 3ddart] #664296
04/08/10 05:40 PM
04/08/10 05:40 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
I was just at Bob Mazzolini Racing in Riverside Calif. and he has a set of the Stage V Engineering heads on the shelf. They have already had the necessary valve job and blending along with port cleanup done. They are nice heads. The Stage V replacement heads are what you are looking for. www.bobmazzoliniracing.com
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: stage V hemi heads [Re: PasiR] #664297
04/08/10 08:21 PM
04/08/10 08:21 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
The replacement head is all you want.
Re: stage V hemi heads [Re: 3ddart] #664298
04/08/10 09:23 PM
04/08/10 09:23 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Tum Banning at FHO gets them in by the crate. I bought them from him as cheap as anywhere else, he worked them over CORRECTLY and shipped them to me. If you buy them from a builder like Tim you will save some shipping charges if nothing else. If there is any profit to be made from a part I would sooner see a guy that does great work get it as opposed to a simple part merchandiser.
Sheldon
Re: stage V hemi heads [Re: RUNCHARGER] #664299
04/08/10 10:06 PM
04/08/10 10:06 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
Not sure if Rick Cassel does the machine work to finish them up or not or can have them done. Regardless of that fact he seems to be a real straight shooter and has been very helpful for me. I actually bought my heads from Mike Cavalieri at hemipartsking. I would bet almost any Stage V dealer is going to be decent to work with, because Eric is probably as picky with choosing dealers as he is his production quality.
Re: stage V hemi heads [Re: RUNCHARGER] #664300
04/11/10 04:01 AM
04/11/10 04:01 AM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Tim Banning at FHO gets them in by the crate. I bought them from him as cheap as anywhere else, he worked them over CORRECTLY and shipped them to me. If you buy them from a builder like Tim you will save some shipping charges if nothing else. If there is any profit to be made from a part I would sooner see a guy that does great work get it as opposed to a simple part merchandiser.
Sheldon
I second Tim, great guy to do business with, would use him again without a hessitation
