Fuel Pump eccentric spinning? #66403
05/30/08 09:48 PM
05/30/08 09:48 PM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
i have an edelbrock rpm cam. Lost my fuel pressure and pulled the pump off to see the eccentric not spinning with the timing gear........looks like it's free wheeling. I thought this was part of the cam on this shaft? If not, aren't they keyed? Um looks like I'll be pulling the timing cover..??
Re: Fuel Pump eccentric spinning? [Re: Dart 340] #66404
05/30/08 09:51 PM
05/30/08 09:51 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Small block it should catch on the cam timing gear key.
Re: Fuel Pump eccentric spinning? [Re: MoparforLife] #66405
05/30/08 09:54 PM
05/30/08 09:54 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Thats what I thought but you can spin it by hand with a screwdriver in the pump hole? What gives?
I looked at the edelbrock site and it shows it's
part of the ground camshaft???
Re: Fuel Pump eccentric spinning? [Re: Dart 340] #66406
05/30/08 09:56 PM
05/30/08 09:56 PM
Upper Midwest
Upper Midwest
Must show a generic picture.
Re: Fuel Pump eccentric spinning? [Re: MoparforLife] #66407
05/30/08 10:07 PM
05/30/08 10:07 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Yea, great. I have to pull the HB and crank pulley to
fix this don't I? The thing ran for a week ok now it's spinning. I don't get it. Must have been bolt pressure only? Maybe there's not a key in it?
Can I run an electric pump this summer and fix over winter? Whats the gamble?
Re: Fuel Pump eccentric spinning? [Re: Dart 340] #66408
05/30/08 10:10 PM
05/30/08 10:10 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I bought this thing from a guy who had more $$ to spend on parts than he had brains. Good god, he put all this money into it without knowing anything about cars! I need to take his welder away also.............
Re: Fuel Pump eccentric spinning? [Re: Dart 340] #66409
05/31/08 12:01 AM
05/31/08 12:01 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Probably not good to let it spin freely. It will eventually eat itself up. -bob
Re: Fuel Pump eccentric spinning? [Re: BobR] #66410
05/31/08 12:24 AM
05/31/08 12:24 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Yea that's what I was thinking. Spent all winter
getting this thing on the road by May and I'm just
tired of working on it. Been a long road so far.
How long is the tear down to get at it? Also can you but a timing cover with degree marks on it as this one has none. Kind of a pain to time.......
Was thinking a long day should do it.?
Re: Fuel Pump eccentric spinning? [Re: Dart 340] #66411
05/31/08 01:39 AM
05/31/08 01:39 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Cam bolt must be loose for the eccentric to spin freely. May have not been lined up with the notch in the eccentric when it was tightened. Not to bad of a job. Pull the balancer, timing cover, etc. I usually put a little loctite on the bolt. Mike
Re: Fuel Pump eccentric spinning? [Re: mopars4ever] #66412
05/31/08 03:24 AM
05/31/08 03:24 AM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Don`t even run that thing. The bolt is loose and if the timing gear falls off it can trash anything, including the block.
That happened on a hemi ram and mopar had to give him a warranty engine.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Fuel Pump eccentric spinning? [Re: gamagoat6x6] #66413
05/31/08 09:47 AM
05/31/08 09:47 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I was thinking maybe he didn't even put a key in it
because he was running an electric pump from the start. I guessed it was only bolt pressure holding it on.
I'm working on it now, looks to be a long day. I hope I don't find anything worse once I get in there. If so, might be a timing gear and cam change.......... great.
Re: Fuel Pump eccentric spinning? [Re: Dart 340] #66414
05/31/08 09:51 AM
05/31/08 09:51 AM
Upper Midwest
Upper Midwest
Has to be a key or the timing gear would also be spinning. The key extends through the gear and hooks the accentric. Then the conical washer and bolt.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Fuel Pump eccentric spinning? [Re: MoparforLife] #66415
05/31/08 10:29 AM
05/31/08 10:29 AM
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
There`s also a two piece cam with an outer ring that spins freely on the inner cam to prevent wear. Could be one of those old ones in there.
Re: Fuel Pump eccentric spinning? [Re: MoparforLife] #66416
05/31/08 11:59 AM
05/31/08 11:59 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Could be. Have to see once I get the cover off.
Anyone have a good way to remove the balancer bolt
without a tool to lock the rotation? Kind of stuck.
Going to try to lock with studs in the balancer pull holes.
Is a tool required? Been a long time since I tore this down.
Re: Fuel Pump eccentric spinning? [Re: Dart 340] #66417
05/31/08 12:09 PM
05/31/08 12:09 PM
Upper Midwest
Upper Midwest
Use an impact on the crank bolt - It will spin it right out. I have at times also taken the pulley off and put a couple of the bolts back in most of the wan but enough sticking out to wedge a large screw driver between to hold the crank from turning while I break the crank bolt loose. One broke loose it is easy. Use a alcheapo steering wheel puller on the damper to pull. Make sure to take the large washer off the crank bolt and then put the bolt most of the way back into the shaft and use it as and anvil to rest the tip of the puller on, Some of the pullers tip will slide into the crank hole and booger the threads up. The damper hole will fit right over the bolt head without the washer on it.
Re: Fuel Pump eccentric spinning? [Re: MoparforLife] #66418
05/31/08 12:13 PM
05/31/08 12:13 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I dont' have an impact... but the store is not that far away. I bent bolts in the puller holes trying that as support. Just to verify, standard thread or leftie?
Re: Fuel Pump eccentric spinning? [Re: MoparforLife] #66419
05/31/08 01:06 PM
05/31/08 01:06 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Well here's what I found. Bolt must have come loose and they key got stripped off then.
Looks like he has a flat washer, then conical washer on this. Should there be a locker or just the conical without the other flat washer? Should you loctite the bolt?
Thanks.
Re: Fuel Pump eccentric spinning? [Re: Dart 340] #66420
05/31/08 01:11 PM
05/31/08 01:11 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Is this a standard store key or is it hardened special?
Re: Fuel Pump eccentric spinning? [Re: Dart 340] #66421
05/31/08 01:22 PM
05/31/08 01:22 PM
MA.
P
plymguy Offline
plymguy  Offline
P
MA.
I made a tool that holds the balancer stationary so the large bolt can be removed and then tightened with the crankshaft turning. It consists of a round steel piece that fits on the balancer after the pully is removed. The holes in the round piece line up with holes on the balancer. It looks like a large washer. There is a piece of pipe welded to the round piece that goes down and hooks under the crossmember beneath the engine. Once in place it works slick. I have used this several times on my '67 Fury with 318 engine.
John
Re: Fuel Pump eccentric spinning? [Re: plymguy] #66422
05/31/08 01:27 PM
05/31/08 01:27 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
The is the cam washer. Should it be bent that much
in the center? The guy had a flat washer on it too
which doesn't seem right.
