rear differential wine at slow down? #663540
04/07/10 07:54 AM
04/07/10 07:54 AM
Lexington,VA
68gtxsurvivor Offline OP
Lexington,VA
Just got my 4.10's installed. The rearend is whining when I let off the gas.Doesn't hardly do it at all when I accelerate. Whats awrong? Pinion depth?
Re: rear differential wine at slow down? [Re: 68gtxsurvivor] #663541
04/07/10 08:52 AM
04/07/10 08:52 AM
MotorCity
RC91 Offline
RC91  Offline
MotorCity
Not enough pinion bearing preload is the usual cause of noise on deceleration.
Re: rear differential wine at slow down? [Re: RC91] #663542
04/07/10 12:06 PM
04/07/10 12:06 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
If you have a crush sleeve you need to use an inch pounds torque wrench when tightening to get the correct drag. If you have shims you might have to remove some.
Re: rear differential wine at slow down? [Re: dmerc] #663543
04/07/10 12:18 PM
04/07/10 12:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Usually once the pattern is set trying to change it is fruitless and the noise is there to stay.
Re: rear differential wine at slow down? [Re: MoparforLife] #663544
04/07/10 05:55 PM
04/07/10 05:55 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I had that problem on a my Camaro after I changed gears and the pinion nut had to be tightened down more. Noise went away. So maybe all you have to do is tighten down your pinion nut somemore.
Re: rear differential wine at slow down? [Re: rapom] #663545
04/07/10 08:38 PM
04/07/10 08:38 PM
scratchnfotraction Offline
crush sleeve
383man [Re: scratchnfotraction] #663546
04/07/10 11:54 PM
04/07/10 11:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Can also be caused by the coast pattern off. I have seen some with the drive side good and the coast side off. Depth and backlash can cause a wrong pattern. Ron
