groan from left rear wheel....bearing? #663469
04/07/10 02:07 AM
04/07/10 02:07 AM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
I am assuming its the axel bearing going out, but was looking for others thoughts. Here is the situation:
70 road runner
4 wheel SSBC disc brakes
green bearings
There is a groan from the drivers side rear wheel. Mostly when I make right turns and will continue while going straight for a few seconds. Turning left makes no noise.
I jacked the rear of the car up and when I turn the wheel by hand the groan is there and is pretty loud, when I remove the tire and spin the rotor assembly the groan goes away, putting the wheel back on and it comes back.
So it seems there is something compressing with the wheel being tightened...
There is nothing rubbing or scrapping...so the only thing I can think of is the bearing going south...any other thoughts?
Re: groan from left rear wheel....bearing? [Re: Bdrainy] #663470
04/07/10 07:55 AM
04/07/10 07:55 AM
scratchnfotraction Offline
my greens did that also one side
then it leak oil at the shaft and bearing
new set and was fixed
do you have the thrust block in it?
I have run a thrust block in a 489 for 9 yrs no problem and the 742 case does not have one for a few yrs now
some say its not good to run the block as the greens do not like side loading
I do plenty of street duty with the one bearing going out after 9 yrs with a thrust block
Re: groan from left rear wheel....bearing? [Re: scratchnfotraction] #663471
04/07/10 08:06 AM
04/07/10 08:06 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
do the SSBC brakes eliminate the old backing plate and not have a similiar thickness plate to replace it? I have wilwoods in back, and that's what these do. it ends up putting the axles too deep, putting a thrust load on them. my first set of greens lasted 5k miles like this. I figured out the problem, and used a spare set of retainer plates as a spacer to replace the backing plate, and no problems 21k miles later....
2017 Grand Cherokee Overland
Re: groan from left rear wheel....bearing? [Re: patrick] #663472
04/07/10 08:45 AM
04/07/10 08:45 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
if you have to buy new bearings. buy the good ones from Dr Diff, member on this site. not the POS mopar ones.
perception is 90% of reality
