Re: Rallye gauge question
[Re: GKMOPAR]
#663449
04/06/10 11:58 PM
04/06/10 11:58 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Do you have 12V going into the regulator.. Its 5V output feeds the guages. Just my $0.01..
[Re: GKMOPAR]
#663451
04/08/10 09:03 AM
04/08/10 09:03 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I can't get the rallye gauges working in my 1970 Challenger. I have replaced the instrument regulator and condensor. I am getting 12 volts to the regulator. I have tried to ground rear of panel with a jumper wire. The alternator gauge and tach work but not the fuel, oil pressure or temp gauges don't. I don't know what else to try. Gerry.
There are only two things in common with the malfunctioning gauges: Ground and the 5 volt regulator. Check the octopus that comes off of the regulator for 5 volts. Use the ground that you have jumpered. If the 5 volts is there, bad news. As mentioned previously, a shorted regulator will pass 12 volts to the gauges and will fry all of the ones it feeds. It does not take much time for this to happen. Good luck, Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: GKMOPAR]
#663452
04/10/10 11:54 PM
04/10/10 11:54 PM
Posts: 821 On the open road
Hrtbkr
On the open road
You'll only get a steady 5V from the regulator if it's an upgraded electronic version. If it's old style, you'll see 12v jumps on your voltmeter needle (it averages 5v over time), Your problem seems to be in the reg... Good luck
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
