Re: Who Supplies the Best Engine Wire Harnesses?
[Re: intragration]
#663413
04/07/10 07:32 AM
04/07/10 07:32 AM
stay away from bill & rose evans' wiring harness, mine sucked on my a12 superbee plus it isnt correct and the leads out of the bulkhead came out twice making me pull my hair out trying to diagnosis the problem.
#663414
04/07/10 01:16 PM
04/07/10 01:16 PM
Posts: 408 Manhattan, IL
SixPackRT
Manhattan, IL
x 2 . Never had an experience with Evans harness's but would suggest the M&H harness to anyone from my experiences.They look original in most every way. Scott
70 Coronet RT 440+6 64 Dodge 330 - Future Hemi Clone 17 Challenger Hellcat - Green Go Driver 86 Buick T-Type Turbo V-6
[Re: 1972Rallye]
#663416
04/07/10 07:18 PM
04/07/10 07:18 PM
I don't think Bill Evans even makes engine harnesses. Year One is the only outlet to get them through that I know of. The harness I got for my '72 was perfect.
wrong. my engine harness is from evans, and it sucks and doesnt look correct at all, especially the ballast resistor connectors. his customer service stinks too!
#663419
04/08/10 07:52 AM
04/08/10 07:52 AM
Posts: 837 Highland, Michigan
1972Rallye
Highland, Michigan
Your right... It was dash harnesses I was thinking of. Maybe I should have said he shouldn't make engine harnesses!
[Re: joelson6]
#663422
04/10/10 12:38 AM
04/10/10 12:38 AM
Posts: 32 pittsburgh, pa
shadango
pittsburgh, pa
There seem to be a lot of folks complaining about bad connections,especially at the bulkhead, if you google Bill Evans wiring. I bought my harness a year ago and had issues almost immediately with the connectors pulling out of the plastic plugs at the ballast...no problem, there...I just removed the plugs and used the metal connectors only. I also found that the wires at the coil were a tad too short, but I made it work OK. But then i had issues where the car would shut down for no reason and I found two bad connections at the bulkhead....wires just pulled out...I soldered those in and sent an email to them, at which point they said send the harness back so they could go over it....But I figure I found my issue and decided to move on...didnt want to have the car dead in the water. Well, now I am having the same issue again this season....contacted them and they told me to send it back for them to examine. On one hand, good support as far as looking at it a year later...on the other hand, have had issues from day one. So for me the jury is out. I purchased a new harness to avoid the issue of possible harness problems......so not real happy. No idea how long it will take to get my harness back....but figured I best have the, go over the harness before looking for issues elsewhere and they agreed. I sent it back via next day air after being told I shouldnt wait because they will be kneee deep in shows soon....then found out today that the main guy is out of town...so I wasted next day air fees.
[Re: shadango]
#663425
04/12/10 09:45 PM
04/12/10 09:45 PM
same exact situation with my harness for my A12uperbee, my car wouldn't stay running. thank God for VCODE who's a electrical guru.came over and found 2 bad connections on my evans harness. sent him a email and wanted it back. i told him that its brand new an send me out another and i'll send the bad one back. didn;t want to tie up my car for that long on a time period. i never sent it back, fixed it and i am buying a yearone harness and no more sales to Evans. poor customer service IMO.i'm tired of dealing with these small mom pop shops with no good return policies.
