Re: I need to pick your brains [Re: maximum entropy] #662885
04/07/10 05:03 PM
04/07/10 05:03 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
No I don't have the clear ones so I can't check that. I do see a lot of vapors comming out of the vent tubes prior to the gush.
6.50 @105.26
Re: I need to pick your brains [Re: maximum entropy] #662886
04/07/10 05:05 PM
04/07/10 05:05 PM
UK
602heavy Offline
602heavy  Offline
UK
Seems you're pulling air through the fuel line , check for any leaks on the suction side of pump , the air is causing the fuel to spill from vent.
Re: I need to pick your brains [Re: Kindafast] #662887
04/07/10 05:22 PM
04/07/10 05:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you changed the needle and seat yet... I would
do that first... its cheap... when the fuel gets hot
and has any agitation it will put out a pile of vapor
and fuel coming in through the needle and seat is
plenty of agitation..... if you have a air leak
(sucking in air, your fuel pressure will show it also),
you can check for one but I doubt you will find one
Re: I need to pick your brains [Re: MR_P_BODY] #662888
04/07/10 05:36 PM
04/07/10 05:36 PM
Seaford, Va
Seaford, Va
I am getting a new needle and seat tomorrow and a new float just in case. I sure hope that will fix it. The fuel gauge don't jump around much so I don't think it would have air in it.
6.50 @105.26
Re: I need to pick your brains [Re: Kindafast] #662889
04/07/10 07:30 PM
04/07/10 07:30 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
No question needle &seats. get 2.
Re: I need to pick your brains [Re: RemCharger] #662890
04/07/10 08:15 PM
04/07/10 08:15 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
It sounds like the needle and seat to me as well .Proly only one end or the other ,but i would change them both...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: I need to pick your brains [Re: The Shocker] #662891
04/07/10 08:29 PM
04/07/10 08:29 PM
Seaford, Va
Seaford, Va
Thanks guy's I will give it a try tomorrow when they show up. I will let you know.
6.50 @105.26
Re: I need to pick your brains [Re: Kindafast] #662892
04/08/10 04:40 PM
04/08/10 04:40 PM
Seaford, Va
Seaford, Va
Well I got all my new parts today. I put them in and went for a little ride. I still don't know wether it worked or not cause I broke a darn roller rocker. I am not dealing with the old Cat rockers anymore and will just save the money for a good set. So for now the carb is the least of my worries. Thanks again for all the replys. Joe
6.50 @105.26
