Hey everyone I am having a wierd problem and I hope you can help. I got my new shortblock in about the same time I bought a new 950Hp carb, so it's been a little while getting everything working right. The engine runs fine and the carb seems to run great until it's run for a while. I can drive this thing around for about five miles and it runs fine , but when it runs a little longer than that it acts like it's flooding out to the point of cutting off. I can shut the fuel pump off and it will run fine until it starts to run out of gas. I have changed the fuel pressure, adjusted the float levels and everything I can think of but nothing helps. If I didn't give a acurate enough symptons just ask. Thanks for your help. Joe
