Re: I need to pick your brains
[Re: maximum entropy]
#662885
04/07/10 05:03 PM
04/07/10 05:03 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
No I don't have the clear ones so I can't check that. I do see a lot of vapors comming out of the vent tubes prior to the gush.
6.50 @105.26
[Re: Kindafast]
#662887
04/07/10 05:22 PM
04/07/10 05:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Have you changed the needle and seat yet... I would do that first... its cheap... when the fuel gets hot and has any agitation it will put out a pile of vapor and fuel coming in through the needle and seat is plenty of agitation..... if you have a air leak (sucking in air, your fuel pressure will show it also), you can check for one but I doubt you will find one
[Re: MR_P_BODY]
#662888
04/07/10 05:36 PM
04/07/10 05:36 PM
Kindafast
Seaford, Va
I am getting a new needle and seat tomorrow and a new float just in case. I sure hope that will fix it. The fuel gauge don't jump around much so I don't think it would have air in it.
6.50 @105.26
[Re: The Shocker]
#662891
04/07/10 08:29 PM
04/07/10 08:29 PM
Kindafast
Seaford, Va
Thanks guy's I will give it a try tomorrow when they show up. I will let you know.
6.50 @105.26
[Re: Kindafast]
#662892
04/08/10 04:40 PM
04/08/10 04:40 PM
Kindafast
Seaford, Va
Well I got all my new parts today. I put them in and went for a little ride. I still don't know wether it worked or not cause I broke a darn roller rocker. I am not dealing with the old Cat rockers anymore and will just save the money for a good set. So for now the carb is the least of my worries. Thanks again for all the replys. Joe
6.50 @105.26
